Old May 14th, 2007, 16:52
HeavyMetal's Avatar
HeavyMetal HeavyMetal is offline
5x4.5 bolt pattern 16.5" diameter rims...do they exist?
do these exist? its a hard thing to use the search for
Old May 14th, 2007, 16:53
85cherokeechief's Avatar
85cherokeechief 85cherokeechief is offline
Re: 5x4.5 bolt pattern 16.5" diameter rims...do they exist?
The only 16.5" rims that are even worth looking at are hummer H1 wheels and they are factory 8 lug. However, they usually need to be re-centered to get normal backspacing so you can get any lug pattern you want, but it will cost you.
Old May 14th, 2007, 19:12
markaboo929's Avatar
markaboo929 markaboo929 is offline
I was wondering about that too,cause you can get 4 brand new Goodyear OZ military tires real cheap like under $400 for a 36x12.50 tire in the 16.5" rims.I know thats what you we're thinkin!!!
Old May 14th, 2007, 19:23
HeavyMetal's Avatar
you are a genius, because yes, that is EXACTLY it hahah. for a project jeep
Old May 14th, 2007, 19:49
saw it on ebay...ehh? plus the guy is local to me here in charlotte,NC.I have'nt actually contacted him yet but I do think you can find old dodge 5 on 5.5 wheel pattern in the 16.5 rims I never did any search or so but I am going to RIGHT NOW!!!! You should be able to get a wheel adapter in that siz e.
Old May 14th, 2007, 22:37
From what I have heard, those goodyear military tires are not very good offroad. So I would do a little research on them before you buy them. Just search Pirate4x4 for some info on them.
Old May 14th, 2007, 22:44
HeavyMetal's Avatar
i know theyre not top notch. but i have very specific plans in mind for the vehicle. and that just happens to include cheap 36" military tires
Old May 15th, 2007, 05:52
alwaysready's Avatar
alwaysready alwaysready is offline
they would go perfect with a camo paint job for hunting in the woods type truck. mostly on road little offroading. alot of height for water crossing..
Lincoln Versailles(Ford) 9" rear end, 58.5" wide, 5x4.5 bolt pattern, discs $700 OBO! Safari Ary For Sale: Private Party Only. XJ ITEMS ONLY 6 June 29th, 2007 19:57
D44 front with 5 on 4.5" bolt pattern Roxtar Modified Tech Discussion 23 October 20th, 2005 06:50
5 on 4" bolt pattern... what vehicle has it? Kejtar Tow Rigs and Trailers 5 June 18th, 2004 23:47
Will these rims fit on a 98 XJ bolt pattern? GoalPoster Modified Tech Discussion 7 November 16th, 2003 13:17
Re: Fancy rims post......found the metric bolt pattern that works... Safari Ary Modified Tech Discussion 11 April 5th, 2003 15:33
