ParkCityXJ
- Park City, Utah
I looked through the last 20 pages of posts before writing this and couldn't find anything exactly like it so I apologize if this question has been asked a million times in the past. Anyway, when driving in 4H, it will intermitently pop out. There is a loud poping noise that sounds like it's comming from the front end somewhere. The 4H light goes out and I can tell that I'm not in 4 wheel drive. It seems to do it more when I'm accelerating and if I let off the gas it will pop back in. If I'm cruising at a constant speed there doesn't seem to be a problem. I thought it was the front axle shift motor so I replaced it and that helped but didn't solve the problem. Looking at the diagram in my Haynes manual I can see that there two check valves in the vacuum lines, could a bad check valve cause this problem? and if so where the heck are they?? Any advice would be appreciated
