Old September 28th, 2009, 10:41
kenallwine kenallwine is offline
Crosspin bolt?
Well this weekend I was up at Harry's-u-pull-it in Hazleton, PA looking for some gear for my '00 XJ.
I found a ZJ with disc brakes to do the conversion however, when I pulled the diff cover, and looked for the cross pin bolt I was surprised to see a non standard hex head bolt.
I'm not sure what exactly it is as it didn't quite look like a 12-point. Could anyone shed some light on this. Nothing came up on the search.
Old October 13th, 2009, 07:31
Re: Crosspin bolt?
Anybody?
Old October 13th, 2009, 07:50
wim hoppenbrouwers's Avatar
wim hoppenbrouwers wim hoppenbrouwers is offline
Re: Crosspin bolt?
Hallo. It is possible that this is a roll pin and not a bolt. Mostly in old Dana non C-clips axles.
You can punch it out.
92XJ wim
Old October 13th, 2009, 09:17
fyrfytr1717 fyrfytr1717 is offline
Re: Crosspin bolt?
Could you describe how exactly it is a "non standard hex head bolt"? Which model and year of rear end are you looking at? A little more information might be helpful.
Old October 13th, 2009, 09:30
kastein's Avatar
kastein kastein is offline
Location: Central MA - keep going till the road turns to dirt, then listen for banjos
Re: Crosspin bolt?
Any chance of pictures? Now I'm curious.
My yard looks like Sanford & Sons.
Please do not PM me about the AW4 info thread unless you have a truly unique question that is not covered by it or info to add. I do not respond to questions answered by the thread.
Definitely do not hunt down my phone number at 3AM, text me about it, and then threaten violence when I am not helpful. It will not get you what you want.
CTeunuch: Sometimes I really wonder if this sport makes you insane, or it just attracts the mentally unstable.
Old October 13th, 2009, 10:47
ghettocruiser's Avatar
ghettocruiser ghettocruiser is offline
Re: Crosspin bolt?
Ive never seen anything other than standard hex bolts. I guess it could be a star head...or reverse torx. I cant remember when I stripped a ZJ axle for the brakes.
J.
Old October 13th, 2009, 10:48
Gaius's Avatar
Gaius Gaius is offline
Re: Crosspin bolt?
I;ve only seen a roll pin, or a 1/4 inch 12 point bolt head.
Old October 13th, 2009, 18:52
lawsoncl lawsoncl is offline
Re: Crosspin bolt?
Being a ZJ, it would be a c-clip axle and probably a 1/4" 12-point or maybe 5/16 12-point head.
Old October 14th, 2009, 06:56
Re: Crosspin bolt?
I think it might be a star head (reverse torx). I believe the year was a 96. I want to make sure I have the right socket to get it out. Anyone know if craftsman has 'star' sockets?
Old October 14th, 2009, 07:03
Re: Crosspin bolt?
Hallo. This is my worn cross bolt. A normal wrench to use:1/4" 12 points.
click for bigger pic.
'92 XJ wim.
Old October 14th, 2009, 22:51
Re: Crosspin bolt?
'92 XJ wim.
Looks a little more than worn if you ask me.
Old October 15th, 2009, 00:14
Re: Crosspin bolt?
Hallo. The cause is worn C-clips and clips grooves in the axles and the LS.
The movement is axial 3mm of the rear wheels.
Sometimes it makes sounds, when the brake shoes are moving with it. LOL
'92 XJ wim
Old October 15th, 2009, 01:04
lilredxj99 lilredxj99 is offline
Re: Crosspin bolt?
it's probably a inverted torx. it can be removed w/ a good combination wrench.
Old October 15th, 2009, 01:08
Re: Crosspin bolt?
Did you try a normal wrench 1/4" too?
Old October 15th, 2009, 05:59
Joshooha's Avatar
Joshooha Joshooha is offline
Re: Crosspin bolt?
the only thing I have for you on that topic is to post maybe a pic of the bolt, otherwise its likely the torx bits they use all over the place. Or get a 12 point socket? I wish I could help out more.
However, how is that junkyard up in Hazelton? I drive up that way from Carolina a lot and pass that junkyard...is it worth stopping to take a look?
How do you remove D30 rollpin holding the crosspin? xj92 Modified Tech Discussion 9 July 20th, 2007 01:18
Crosspin for 8.25 Open carrier? djblade311 SoCal Chapter 1 March 11th, 2006 20:57
Switchin yota rear bolt bolt pattern... mwm Modified Tech Discussion 5 December 8th, 2005 18:33
Getting arb lock tab to seat on bolt head--rev dana 30 6 small bolt on top Big Red Modified Tech Discussion 4 October 26th, 2004 17:09
8.25 4.56 gears crosspin not fitting! JasonXJ Modified Tech Discussion 14 August 3rd, 2004 05:02
