The ignition switch is at the bottom of the steering column, operated by a rod down from the key cylinder. They do eventually give up the ghost.....cheap to replace, they are a standard GM type. I would start by checking that the rod moves the switch, and look at the contacts. If those check out, replace the switch. Anybody know a good switch test procedure? 4xBob
