- Bakersfield, CA
Does anyone know what RPM the rev limiter is at on a Renix system? I've never hit it, but I assume it has one. Also, what opinions do you guys have on how high you could run a stock 4.0L motor.
Goatman said:How high do you guys run your strokers? Are you motors balanced? Rods reconditioned and shot peened?
Dr. Dyno said:I've run my 4.6 stroker up to the 5200rpm rev limiter and it's smoother than my old 4.0 at that rpm. Rods and pistons weight-matched to less than 1g, rods shot-peened, and I used ARP rod bolts. I have the stock camshaft and stock valve springs with no valve float issues up to 5200rpm.
Goatman said:Does anyone know what RPM the rev limiter is at on a Renix system? I've never hit it, but ...
JJacobs said:Renix engines don't have a rev limiter. Mine didn't, anyway.
That was the top speed recorded on my GPS.KMK172008 said:how do you know it was 119.3? did you have a vbox or something?
Wow said:I decided to try and find the speed limiter on my XJ...was at 5000+ for at least a minute. That's the closest thing as I can imagine to what blasting off in a space shuttle is like. Everything was wobbling and whining and sounding like it was going to come apart. It was a fun ride though...:nono:
Speed limiter hit at 119.3 mph, BTW.
Talyn said:Auto or manual? gears? tires?
In stock form I don't think your would be redlining at 119 mph. That is where the speed limiter kicks in, maybe that is what it was.
