Old October 8th, 2018, 15:46
Sub Zero Sub Zero is offline
Tire size recommendations
So after a fiasco with my suspension upgrade, I finally got my new lift and shocks done. RE 3.5 leafs and RE 1.75 coil spacers. The leafs ended up giving me 5" of lift si I used the coil spacers to help level it and ended up with around 4.75" in the front with OME shocks all the way around. I wasn't planning on a bigger lift, but since the leafs gave me so much extra lift I just went for it. Now my 31s are looking pretty small, so I'm looking for tire size recommendations without cutting my fenders. I will also be getting different wheels to get better back spacing. I'll post a pic as soon as I remember how. Thanks
Old October 8th, 2018, 16:07
Re: Tire size recommendations
Old October 8th, 2018, 16:09
Old October 8th, 2018, 16:14
Old October 8th, 2018, 16:36
Cottontail's Avatar
Cottontail Cottontail is offline
Three-De Off-Road
I'm about the same lift size as you and I run a 265/75/16 on stock Jeep rims. I think it fits perfectly with a trimmed front fender and a cut and fold rear.
[IMG]IMG_2929_2 by Dirk DeYoung, on Flickr[/IMG]
Dirk DeYoung--Member #176--National Vice President, SEC President
You'll never leave Harlan alive.
1996 ZJ (200GRND)...2001 XJ (TRALRIG)...2006 XK (TOW RIG)
Old October 8th, 2018, 16:52
I'm really on the fence about cutting the fenders. I know I could get away with 33s if I end up cutting them, but I kinda like the look of the stock flares
Old October 8th, 2018, 17:33
Ivan's Avatar
Ivan Ivan is offline
I Jeep, therefore, I am..
I went with 32's and stock flares on my 5.5" lift, with no sheet metal cutting or folding. Full stuff and no rubbing anywhere. I do have a tube front bumper, so that provides adequate front clearance.
I know I can't do that with 33's without hacking into sheetmetal, and my setup suits my needs just fine otherwise.
Member #133
Kleptomaniacs help themselves, because they can't help themselves......
Old October 8th, 2018, 17:34
RCP Phx RCP Phx is offline
I was running 33's with some trimming and rubbing. I now only run 265/75/16's without issue, I won't be going back. I use to change out the tires/wheels just for wheeling but it's just not worth it!
Old October 8th, 2018, 18:51
I'd like to get a front bumper eventually, but I have no problem with trimming the bumper end caps for now 8f needed
Old October 8th, 2018, 23:18
lazyxj's Avatar
lazyxj lazyxj is offline
NAXJA Member #1310
Here is an old photo of mine.
4" lift and 33 X 10.50-15s, on stock rims.
The fenders have been trimmed and the flares moved upward.
Both XJs are still Real XJs http://www.naxja.org/forum/showthrea...hlight=real+XJ
01 Sport, 4.6L Russ Pottenger. stroker, AW4, 4" lift, 33 X 10.50 KM2, 4.56-8.25 TruTrac, D-30-E-Locker with alloy shafts, Hidden M8000 winch, Vanco front and ZJ rear disc brakes, Frame stiffeners, Lots of armor, Towing baseplate. http://www.flickr.com/photos/lwade/c...7603770130683/
1997 Country, Mostly stock, 2" lift, Engine mods, Towing baseplate
Old October 8th, 2018, 23:52
Larry
That looks really good. Any idea how much sheetmetal you cut off?
Old October 9th, 2018, 03:50
I love all the silver ones! Front is 3" w/ 31's and my other one is 5.5" on 265's.
Old October 9th, 2018, 10:21
smokeyyank's Avatar
smokeyyank smokeyyank is offline
XJholic
Great write up to get more clearance and still keep a stock look
http://www.yuccaman.com/jeep/trim.html
Old October 9th, 2018, 17:40
Bent's Avatar
Bent Bent is offline
Only Slightly Psychotic
4.5" lift and 31" tires if the point of all this is vehicle capability. 33s work really well at the mall at that height.
Gravity is a fickle mistress.
Ethan: "What did you think would happen?"
'01 XJ • 4.0 • AW4 • 231 • Modified
'87 MJ • 4.0 • AW4 • 231 • Stock-ish
SoCal Chapter VP
Old October 9th, 2018, 23:35
4x4JeePmaNthINg's Avatar
4x4JeePmaNthINg 4x4JeePmaNthINg is online now
32s will still rub, 31s fill an xj wheel well prefect. I'm on 33 now and trimmed.
Unless you bump stop ide go 31s, I can't speak to metric sizes.
tire recommendations? ericfx1984 Modified Tech Discussion 22 February 25th, 2011 10:19
Tire Recommendations sam24th South East Chapter 11 February 11th, 2011 19:22
Need Lift/Tire Size Recommendations bdl220 Modified Tech Discussion 10 March 26th, 2006 11:05
Goin to a full size spare, recommendations? 93GRNXJ OEM Tech Discussion 6 September 11th, 2003 16:38
'00 XJ - Tire recommendations? gw204 OEM Tech Discussion 31 June 24th, 2003 22:59
