Old October 8th, 2018, 12:25
4x4JeePmaNthINg's Avatar
4x4JeePmaNthINg 4x4JeePmaNthINg is offline
Jw2 vs trucklites
Is anyone running the new jw2 Headlights?
Any other thoughts on preference between the two?
Old October 9th, 2018, 08:08
Redsnake Redsnake is offline
Re: Jw2 vs trucklites
I'm running the JW Speaker 2 LED's in my 01 XJ and love them. I've tried several different version of headlight upgrades and these have been my favorite to date. I've not tried everything, but the JW2's look the best and have the best beam pattern so far.
Old October 9th, 2018, 09:45
RCP Phx RCP Phx is offline
I love the ones I bought, so I bought a second set for my other 2k.
Old October 9th, 2018, 09:48
Used to have a guy that would somehow get behind me almost every morning in his Jeep on my drive into work w/those multiple led headlights... and they were horribly blinding!! Super bright I'm sure but they had virtually no cutoff and were blinding. :/
Old October 9th, 2018, 11:57
xj_mike's Avatar
xj_mike xj_mike is offline
I am running a set of JW Speaker Evo 2 after buying a set of the cheap ones many buy. The cheap ones totally sucked, no pattern and was almost worse then the stock lights. Had them 1 night and sent them back. Before I bought these I had done a ton of research on lights and the JWSe2 were by far the best but also most money. I knew I should have just bought them to start but so many were raving about the other lights, I thought I would try them.
Hands down, the JW freaking rock! Great pattern and cutoff, freaking high beams are like the sun came out. They work so well I decided not to buy any auxiliary lights for the front. I used to hate driving at night and now I find reasons to do so.
Trucklites are very good and I know others who have used the round version in other rigs. Are they cheaper then JWS, yes but not better. Can't go wrong with either but I would buy another set of JWS in a heartbeat.
XJ_Mike
1999 Cherokee Sport 4x4, Still stock...
2000 Cherokee Classic 4x4, Lots of stuff. SOLD but should have kept...
Old October 9th, 2018, 12:42
bigdaddyjlove bigdaddyjlove is offline
I run the Truck-Lites in my DD and I love them.
Old October 9th, 2018, 18:22
Heavyopp Heavyopp is offline
I have a set of JW speaker evolution J in my wife’s JKU — they are an amazing upgrade
They did cost just under $500 though — that 2.5 times what I paid for my entire 2000 XJ
Old October 9th, 2018, 23:30
How's the winter driving, does anyone have the heated version. I was disconnecting sway bars today and it was snowing. I could feel the heat off the halogens. I have the harness upgrade, but I think I can kill 2 for one with great headlights vs adding extra pods.
Dumajones has done really good reviews on YouTube, but ide like some more opinions.
This far you all seem to take JW AS a step up over trucks.
Do you like the distance the high beam travels, I have a dual amber bar, but want to add great spots. I hope some really good headlights would be great!
Old October 10th, 2018, 05:00
I live in OK so we don't get a ton of snow/ice... but I've never had any issues w/my headlights fogging up. I know they're not as hot as the Hella 100W bulb setup I used to have, but those bulbs would also pop about every 6-12 months... and normally in the rain or bitter cold weather. So I can't say how they'll do in Colorado (assuming your location) but if I were you, I'd opt for the heated version just to be safe assuming you can swing the extra $$. As far as high beam distance... it's fantastic! To be honest I've never really even needed to run the high beams but when I do for fun, they definitely project high and far. Almost like I just turned on 2 spot lights.
Old October 10th, 2018, 11:44
xj_mike's Avatar
Living in SoCal, not really snow/ice to deal with... heck hardly any rain either...
I would think if you live in an area you get regular snow/ice, the heated ones would be the way to go. If very light snow, maybe not but if you are getting inches, I would say yes.
As for the high beams, It's like adding very bright spots. I haven't felt the need to add anymore lighting to the front.
XJ_Mike
Old October 10th, 2018, 18:35
trippled trippled is offline
If it's snowing hard enough halogens still won't melt the snow if you're moving. Hjeepxj has LEDs on his, he's up near you. Might ask him how his do.
Best driving/long range lights I used we're the old hella 500 lights. You could see 1/4 mile down the road and reflective signs from +1 mile out. I plan on reusing them on one of the Jeep's one day.
Old October 11th, 2018, 04:51
Jeep Driver Jeep Driver is offline
Yes, there are a couple of assholes round here with lifted trucks that have those cheap LEDs.
Coming at you or behind you they are blinding.
I'm buying the JWS.
Old October 11th, 2018, 06:51
Anyone ever run predators vs jws, JW still seems to set the bar. I don't think anyone else makes heated. Maybe it's overkill for most idk.
Ive had lights pack with snow multiple times, usually on high mountain passes where any light would be as doomed, ide hope LED are fine in most snows.
Old October 11th, 2018, 07:20
I know it's different, but I have several high-power LED handheld flashlights and those things get HOT towards the head of the flashlight. I wonder why the LED Headlights don't generate as much heat... :/
Old October 11th, 2018, 07:37
Lowrange2's Avatar
Lowrange2 Lowrange2 is online now
Member# 2368
I have the Predators from Highbeam Offroad on one Jeep and Trucklites on another Jeep.
The Trucklites have a far superior (brighter) lowbeam but have the transformer head looking hot spots. They have nice high beams and throw light a significant distance for an LED.
The Predators have a much nicer pattern on low beam with no hot spots but aren't as bright and don't have as sharp of a cut-off line. Highbeam is on par with Trucklites but doesn't seem to be able to throw the distance that TL can. Predators are half the price of Trucklites.
Overall, I prefer the Trucklites.
Bumpers, Winch, Trucklites, etc. FOR SALE stumpXJ SEC For Sale / Wanted Forum 18 November 21st, 2013 19:02
