Water Pump Pulley Torque Specs....
desertred
Anyone know what they are? For the life of me, I can't find them anywhere in the FSM. Have the specs for all the other bolts, except the four bolts holding the water pump pulley onto the flange. Thanks. (88XJ, 4.0 if it makes a difference).
Alldata has the water pump pulley torque at 20 ft lb on my 1995 XJ with inline 6.
In case it helps anyone arriving here with similar questions, the pump's four bolts to engine are 22 ft lb.
Putting the blocking power steering pump back in place, these are all 20 ft lb.
Both bolts on the back of the pump.
Bolt above pump pulley.
Locknut below the pump pulley.
Bolt hidden behind pump, that holds bracket.
F and G bolts in diagram are 28 ft lb.
Yt7QZ96
