Old February 15th, 2008, 09:19
indy_xj indy_xj is offline
Re: 0331 head swap, mpg change?
Originally Posted by Hawg130
Hey Indy, what did you do about securing the coil pack? I'm considering doing this and need some pointers. Thanks.
write up w/ pics here http://www.naxja.org/forum/showthread.php?t=937214
Old February 15th, 2008, 11:51
XJ01-08's Avatar
XJ01-08 XJ01-08 is offline
i swaped out my 0331 head for a newer one, i didnt know how to adapt the older head then, and the head cracked just b4 winter so i cant really compare my MPG from then to now but it is lower then it was b4 i swapped it out
Old February 15th, 2008, 13:37
falcon556's Avatar
falcon556 falcon556 is offline
I have not Confirmed, or I used a BAD email Addy
I had a sudden drop in mpg, drove me nuts trying to figure it out till I learned that most of the gas stations in my area switched to E10 and never said anything. I found one place that still sells real gas and my mpg went up again.
Old February 15th, 2008, 16:41
interesting. I just heard a blurb on the radio today about e15 gas. Might be making its way to my neck of the woods. I'll keep my eye peeled.
thanks,
ixj
Old February 15th, 2008, 18:25
XJ01-08's Avatar
Thats why i need to stop getting my gas at walmart lol
Old February 15th, 2008, 18:52
BIGSLVRXJ BIGSLVRXJ is offline
I run E-10 in mine, I notice no difference between it and regular gas. Now running E-85 is playing with fire.
Old February 15th, 2008, 19:12
CheapXJ's Avatar
CheapXJ CheapXJ is offline
just a thought here...
recheck the torque on your intake/exhaust manifold bolts.
EVERY time I've had them off, I've ALWAYS had to retorque them a week later.
could just be a simple vacuum leak.
Old February 16th, 2008, 04:24
birchlakeXJ's Avatar
birchlakeXJ birchlakeXJ is offline
Lots of states mandate E10 and it isn't a problem to run it on most vehicles. E85 should be run ONLY in vehicles designed for it. Flex fuel vehicles direct from the mfg and vehicles that have undergone a conversion to allow it.
Fuels with enriched blends Ethanol will get less MPG compared to pure gasoline. Gasoline has 104,000 BTU/gal, E10 has 100,700 BTU/gal, and pure ethanol has 70,300 BTU/gal. Various estimates say vehicles with using the E85 blend will get 15 to 25% lower MPG.
Ethanol contains less energy than gasoline, so ethanol blends get fewer miles to the gallon. Ethanol advocates may make the claim that the drop is 2 percent or less for E10 but Iowa State University Professor Larry Johnson and other independent testing estimates that E10 delivers 96.4 percent of the miles per gallon of gasoline, a drop of 3.6 percent, and E85 delivers only 80 percent.
Based on numerous studies, a vehicle that gets 25 miles to the gallon (yea, not our XJs) and has a 17-gallon tank could go 425 miles on a tank of pure gasoline. That same vehicle would get 24.1 mpg with E10 and travel 410 miles, or get 20 mpg with E85 and go 340 miles.
Old February 16th, 2008, 15:29
yeah, did that about 2 weeks ago. Bottom ones were all tight. I think 2 of the top ones had backed out about 5 lb-ft or so. spec is 24 lb-ft for anyone wondering.
ixj
Old February 17th, 2008, 20:57
XJ01-08's Avatar
Knew i forgot to check something
0331 head change results indy_xj OEM Tech Discussion 96 October 11th, 2011 06:04
Would you buy a 2000 with the 0331 head? rocknxj Sierra Chapter 7 February 11th, 2008 05:27
valve carbon or 0331 head issue? 0630 swap? wilsmick OEM Tech Discussion 12 May 22nd, 2007 20:13
NY: 0331 HEAD (CRACKED) mtsz52784 FREE Items. No SPAM 0 May 12th, 2007 10:15
0331 head [low emission] Dmanti OEM Tech Discussion 4 January 9th, 2007 17:48
