Old December 12th, 2005, 13:39
summitlt's Avatar
summitlt summitlt is offline
Is it worth swapping the np231 for the np242
I have one sitting here, the full time case. And was thinking of swapping it into my MJ for the New england winters. I dont have any problems with the 231, but figured itd be nice with the 242.
Are there any drawbacks to having the 242?
All I need is
Front DS?
console stuff
linkage
right?
Old December 12th, 2005, 14:04
88XJ_FireFighter 88XJ_FireFighter is offline
Re: Is it worth swapping the np231 for the np242
I love my 242 for the Iowa winters.
Old December 12th, 2005, 14:29
casm's Avatar
casm casm is offline
Had a 231 previously, have a 242 now. Wouldn't go back if you paid me, unless the sum of money involved was ridiculously huge.
Old December 12th, 2005, 15:39
funvtec's Avatar
funvtec funvtec is offline
what exactly are the pros and cons i have a 242 in my limited
just curious
Old December 12th, 2005, 16:11
casm's Avatar
The 242 has a centre differential, which the 231 does not. In practice, what this means is that the 242 gains a full-time 4WD position (4FT) that can be used on solid surfaces. Effectively, it gives you an AWD high range suitable for use on pavement by allowing both the front and rear axles to turn at different speeds. In rain & snow this is extremely useful, and I've found it great out in the desert on all but the deepest sand.
The 231 lacks the centre diff, so no 4FT range. This means that using part-time 4WD (4PT) on pavement unless you're moving in pretty much a straight line is a bad idea: because the front and rear axles can't move independently of each other, when you turn the steering wheel you start introducing hop at the CV joints. Turn it far enough and you'll bind the axles completely.
Old December 12th, 2005, 16:12
funvtec's Avatar
good info, i had no clue
thanks
Old December 13th, 2005, 09:54
dmillion dmillion is offline
Well, I'll play devil's advocate and offer the opposite view. I've had a 4-wheeler with a transfer case with a full-time option in the past and my current XJ has the 231. I don't think the benefits of full-time 4WD are worth the effort to make the swap, even if you do already have the t-case sitting there.
With shift-on-the-fly you can put your 231 into 4WD anytime you need it, and then take it out when you don't. The only thing a 242 t-case gives you is the option of saving the teeny-tiny bit of effort that's involved in shifting into and out of 4WD.
Now, some people will say, "but you'd have to be constantly shifting back and forth in some situations," to which I say, nonsense. I live in Colorado, drive up into the mountains regularly, see ice and snow all the time, and have yet to see conditions where I needed to be constantly shifting into and out of 4WD. What I see are conditions of two types: 1) It's pretty bad and you shift into 4WD and leave it there; the few small patches of dry road are not enough to cause any problems when in part-time 4WD. 2) It's not so bad and you only need to shift into 4WD very infrequently; maybe sometimes when you start off, and once in a while to give you more control going around a corner.
Another thing some people will say is, "with full-time it doesn't matter if it's icy or not, I just put it into FT and go without even caring!" Now, those are the people to WATCH OUT FOR!!! You can't drive like the road is dry, just because you have it in FT-4WD. You still need to be aware and careful when it's slippery, because your Jeep in FT-4WD will not stop any better than any other car on the road, and it won't corner any better than any front-wheel drive car out there (like my Toyota Corolla, which does very nearly as well on snowy roads as my Jeep).
If you really want to be lazy then do the swap. You've got the t-case already anyway. I wouldn't bother, though. I'd just keep the other t-case as a spare.
Old December 13th, 2005, 13:31
Curious, how will be be lazy by doing the swap???
Old December 13th, 2005, 13:32
I meant lazy in the sense of wanting to put it into FT-4WD and then not shift into and out of 4WD as the conditions of the road dictate.
(Oh, by the way, I lived in Iowa for four years, too--the Des Moines area, Clive to be exact.)
Old December 13th, 2005, 13:41
glub glub is offline
Don't know if it is worth the hassle of swapping, but I like it since I don't have to explain to anyone how to use 4x4 if they borrow my Jeep. I just put it in full-time for the wife the odd time she drives it in the winter and no worries. Otherwise, I'd have to rely on her to switch it in and out (below 88 km/h btw) and also confirming with lights and feel that it did switch. Pulling the handle isn't hard, but overall it's not user-friendly for the casual driver. I wouldn't want her to drive it in just 2wd, since she hasn't driven too many torquey rear-wheel vehicles... that + slippery roads is not fun (unless that's what you're looking for)
That said, I'd just as soon as operate in front wheel drive only in winter and just engage the rear wheels when needed.. ghey but true!
Old December 13th, 2005, 13:50
Originally Posted by glub
That said, I'd just as soon as operate in front wheel drive only in winter and just engage the rear wheels when needed...
I agree! My "ideal" transfer case would have two levers. One would operate to put it in front-wheel drive, rear-wheel drive, or 4-wheel drive. The other would operate to put it in lo-range, hi-range, or neutral. You would be able to do any combination and everything would be shift-on-the-fly.
I'd use rear-wheel drive, hi-range for normal, dry roads. I'd use front-wheel drive, hi-range when the roads are a little slippery, but not too bad--heavy rain, light snow, patchy ice, etc. 2WD (either front or rear) and lo-range would be available for those times that you're in heavy traffic, creeping along at 3 mph. And, of course, 4WD (hi or lo) would be there whenever you needed it.
Old December 13th, 2005, 16:25
falcon556's Avatar
falcon556 falcon556 is offline
I have not Confirmed, or I used a BAD email Addy
Up to now I've had 4 Cherokees. 3XJs and 1 Wj.
My first had a FT(242) TC and liked it. The only time I ever put it in PT was when I was stuck in deep mud or snow. Then I bought the two XJs with part time only cause I coudn't find one with FT at the time.
Later I bought for the wife the WJ with FT and it was obvious to both of us that we liked the ability to go FT.
During the last snow, she put hers in to FT and hasn't touched it yet.
Considering that she gets great traction all the time including in rain, I think she'll keep it in FT all the time.
The WJ ran great and she never had the need for PT.
I think we got it backwards it is the FT that is the most usefull not the other way around.
In a few days I will swap my 231 for a 242 and plan to do the same on my other XJ soon after that.
I didn't like getting the 231 PT TC in the first place and I'll be glad to get rid of it.
Old December 13th, 2005, 16:53
funvtec's Avatar
so does the 242 send all the power all the time in PT to the 4 wheels and FT sends it there when slipping?
because when i got myself in a big rut i had1 front tire in the air and it just spun freely and didn't help me at all to get out as a matter of fact if i remember correctly the left front spun free as did the right rear. i always thought it was becaust i have open rearends, the back really never opens until i have 1 tire firmly planted and the other is in the air or really loose
how does it make it better for on the road driving in FT? if your differential do all the work as far as turning and stuff what could bind up if you were allowed to have the inside tire spin at a different rate in any 4 wheel drive setting?
Old December 13th, 2005, 17:12
falcon556's Avatar
I have a 242 TC on my bench right now. In FT if I turn the input shaft, both front and rear output shafts turn, if I prevent either one from turning the other continues turning.
In real life, you get all the traction you need for all kinds of weather in town.
For offroading, there are cases were the part time pays off.
The good thing about the 242 is that you loose nothing, you gain an option.
In rain you cannot use PT, in FT you cannot spin a tire.
Old December 13th, 2005, 17:18
Kejtar's Avatar
Kejtar Kejtar is offline
PostMaster General
Not to bag on anyone, but if someone feels the need for FT for when it rains, they need to learn how to drive.
NP242 to NP231 Swap Question XJBill Modified Tech Discussion 15 March 18th, 2008 20:39
NP242 TO NP231 swap...possible? 89xjgrey Modified Tech Discussion 12 July 7th, 2005 22:23
np242 np231??? scottkarduck Modified Tech Discussion 14 December 3rd, 2004 08:37
Rubicon 4.5 kit is it worth the money for the spring packs? upandovr Modified Tech Discussion 14 December 10th, 2003 19:16
Np242 vs 231 Differences Boz88xj Modified Tech Discussion 1 March 29th, 2003 13:46
