Go Back   NAXJA Forums -::- North American XJ Association > NAXJA Other Technical Forums > JeepSpeed, Prerunner and Competition Tech Forum
JeepSpeed, Prerunner and Competition Tech Forum For Discussion of Modications related to Prerunning, JeepSpeed, KOH, Rock Racing, and any other speed based competitions
Old January 6th, 2010, 07:39
Larrythedog Larrythedog is offline
Sick Dog Racing Jeepspeed Build
Well here i go, starting my Jeepspeed build. My donor Jeep is a 1987 four door XJ 4X4, with a 4.0.
It had some front end damage but I got it for a song.
Interior Gutted and seats mocked up.
Seat mounts
Had to make some slight adjustments to the floor to get the seats to fit
Seat in and starting on the cage mounting plates.
A Piller mounting plate
B Piller mounting plate
B and C pillers
D Piller mounting plates
Old January 7th, 2010, 19:10
Re: Sick Dog Racing Jeepspeed Build
I started installing my new full traction 6" kit today. I've done a lot of reading on this kit and in my opion its the best long arm kit for your money.
Started with the LCA mount. I wanted to renforce this mount and tie it into the cage mounts as well as the front spring mount on the rear axle. I fabed some bushings to weld through the frame then weld it on both sides of the frame rail to help spread the load.
I then bolted bosses to the frame.
The whole stiffener is removable and is tied into the front leaf spring mount with a 1/2" bolt. I plated the front leaf spring a little, but I plan to replace these mounts with the Poly Pro mounts after I get some seat time.
I have a new found respect for anybody who has welded on these unibodys.
Old January 7th, 2010, 20:46
tbburg's Avatar
tbburg tbburg is offline
Where you pounded in the hump on the drivers side; is that going to cause a clearance problem for the transfer case, or are you converting to 2wd only and it's not an issue,..
Old January 7th, 2010, 20:47
dakineJ dakineJ is offline
Looks good , nice engineering. If you get tired of the longarm part of the kit let me know .
Old January 7th, 2010, 21:24
Baja_XJ Baja_XJ is offline
Lookin good! Glad to add another to the crew that fabs and dont buy everything and bolt it on
Old January 8th, 2010, 09:01
No real clearance problem. Just about every Jeepspeep build has to massage the floor to get the head clearance needed. It will be run in 2WD with a 2WD front beam, but I'm still using the transfer case. I like the idea of running 4X4 for the rougher/longer races.
Thanks. If I do you'll be the first I call.
Thanks. I'm pretty much locked into that "do-as-much-as-I-can" mind-set. I would love to just hand someone 50K and say "build me this". But times are tough and I have to make every penny count. The cage will be the only part of this build not done by myself. I'm having M&D Motor Sports in Iwrindale CA do all the cage work.
Old January 8th, 2010, 11:53
National Drivetrain National Drivetrain is offline
Larry,
I still have my old rear bumper. You can have it if it saves you some time/work. Your ealy on in your build, so it could easily be bolted up to your car.
Let me know, either someone gets it or I have to chop it up.
Located in Lake Elsinore.
Thanks,
Eric
Old January 8th, 2010, 17:57
tbburg's Avatar
Originally Posted by Larrythedog View Post
No real clearance problem,... ..., It will be run in 2WD with a 2WD front beam, but I'm still using the transfer case. I like the idea of running 4X4 for the rougher/longer races.
Just curious about clearance. My buddy has the T-case hump completely cut out and filled in on his 2wd MJ racer, we've been arguing about weather or not a T-case will still fit under the seat. (he's thinking about a 4wd conversion)
And ya, I hear ya on the lack of space to make everything fit. Just feel luck you don't have a cab close out 4" behind the front seat.
Old January 8th, 2010, 17:59
Larry,
Thanks,
Eric
Sure, thanks that will help. Can I come by Monday?
Old January 9th, 2010, 14:49
Monday sounds good, I'll PM you my addy and ph#
Eric
Old January 10th, 2010, 13:38
DesertRunner DesertRunner is offline
im in your neighbor hood if ya need a hand.
Old January 10th, 2010, 14:58
47gmhracer 47gmhracer is offline
Eric
if he doesn't get it let me know!
Old January 10th, 2010, 15:42
GrimmJeeper's Avatar
GrimmJeeper GrimmJeeper is offline
and if HE doesnt get it, let ME know. my XJ is in perris, right next door
Old January 10th, 2010, 16:37
You should come by some time, check out the jeep and have a beer.
Old January 10th, 2010, 17:31
Tying the B piller bottom cage mounts to the front leaf spring mount.
Tying A and B piller bottom cage mounts
Tying into the A piller bottom cage mount.
Tying in to the trans crossmember.
Rate This Thread:
JeepSpeed FAQ ----- (If you plan on racing, read up here) whooprunner JeepSpeed, Prerunner and Competition Tech Forum 17 December 2nd, 2013 20:42
Gadzooks racing on FaceBook - Jeepspeed 1717 DieselSJ JeepSpeed, Prerunner and Competition Tech Forum 9 October 1st, 2009 14:53
My Jeepspeed racing prerunners Tom_T&Js_Offroad SoCal Chapter 21 September 30th, 2008 12:42
i think i wanna build a jeepspeed... slcpunk74 JeepSpeed, Prerunner and Competition Tech Forum 24 May 11th, 2008 10:15
Jeepspeed racing Grzz701 SoCal Chapter 4 June 26th, 2005 18:38
