Old January 3rd, 2018, 14:28
obxxj obxxj is offline
1984 Cherokee XJ Y tube search
Hello All,
After a little over 300,000 miles (second engine) the Y tube part of my exhaust to the 2.8l engine has given up the ghost. The Y tube seems to be no longer available commercially. Any ideas? Cost for those ideas? Many thanks!
David
Old January 3rd, 2018, 14:43
Green Mesa XJ's Avatar
Green Mesa XJ Green Mesa XJ is offline
Itís not available anywhere as far as I know. Maybe NOS someplace.
Iíve heard some people used s10 or Camaro 2.8 Y pipes. The only obvious deference I saw from online pictures was those Y-pipes didnít have the flange for bolting the catalytic converter (most shops probably welded it together if it was ever replaced). Although some swear it did have the cat flange)
Iíd have to do some more research to find that thread again and see if it was the Camaro or S10 for the alternate part.
If you have a local parts house with the Chevy Y-pipes In Stock maybe you could compare them.
Only other option for the jeep Y-pipe was a exhaust kit that also is no longer in production.
Old January 3rd, 2018, 14:53
Found it a guy with a 84 XJ bought Napa 1984 S10 2.8 y-pipe. Someone else said their S10 Y-pipe did have the flange for the catalytic converter but he didnít leave a part # or source.
Old January 4th, 2018, 09:55
four_shot's Avatar
four_shot four_shot is offline
How 'bout it Gonzo
Re: 1984 Cherokee XJ Y tube search
X2 on the s10 y pipe. Flange should be attached. You may need to plug an O2 sensor bung.
4shot
"Babs" 97 sport 4.0 aw4
R.I.P."Buster" 86 laredo 2.8 ax5 10/85-9/17
In memory of Dave "Gonzo" Steele 1975-2008
Old January 12th, 2018, 10:44
Thanks everyone for the S-10 Y tube steer!
David
1984-1996 Tube Doors BIGSLVRXJ MWC For Sale/Wanted Forum 9 March 4th, 2008 09:59
1984 cherokee v6 install 4.0L techshooter02 OEM Tech Discussion 2 February 17th, 2008 20:26
1984 cherokee-2.5l mods? bcmaxx Modified Tech Discussion 1 August 28th, 2007 13:35
1984 cherokee 5.0HO av4xj Modified Tech Discussion 21 November 21st, 2005 22:07
1984 Cherokee XJ xj-fx For Sale: Private Party Only. XJ ITEMS ONLY 1 June 26th, 2003 20:59
