T98 4.0 auto. All lights work except tail lights. Has trailer light plug. Tore the panel open behind the spare. When I disconnect the rear ground with just a single wire i get partial lighting. The left side is about right but the right side is extremely dim. Also with ground disconnected my left rear blinker stops working in the rear and semi flashes through tail light bulb. Also with ground off the tails wont shut off with the switch. When i reconnect the ground they cut out and my left blinker works correctly. Is this a bad connection somehow back feeding? Please help.
