edog500cc
- California
Jeep has been running great then all of a sudden while driving it started running very rough and backfiring in the intake. Tested the fuel pressure, its where it should be both off and running (44 psi engine off and 32 psi running) and no leak down. Changed O2 sensor, cap and rotor. See no vacuum leaks or cracked/disconnected lines. Checked MAP, TPS, CPS, IAC all seem good. Throttle body clean. New bosche 4 port injectors from K-suspension about 2 months ago. New plugs and wires about 2 months ago. #4 and #6 plugs were fouled when I checked them indicating misfires there. Cleaned all plugs checked gaps and replaced. No crack visible on the exhaust manifold. Intake/exhaust gasket looks good around the edges at least. Still have a visible miss on tach, semi rough idle and steady backfire in the intake. A few weeks ago I removed my Catalytic converter and if anything the Jeep has been running better since then until this happened. I did notice a few days before this happened the idle seemed to be a little higher than normal but not sure if that's unrelated. Help please! I'm going insane
