Go Back   NAXJA Forums -::- North American XJ Association > NAXJA Chapters > Colorado Chapter
Colorado Chapter Discussion of Chapter issues. Please keep Tech Topics on the Tech Forums.
Thread Tools Rating: Thread Rating: 35 votes, 4.89 average. Display Modes
  #5431
Old July 23rd, 2021, 13:13
1-tonxj 1-tonxj is offline
Re: What are you doing to your rig - the continuing saga
Originally Posted by smokeyyank View Post
Nice, I'll be interested to see how it turns out. Are you using a stock size rad or?
I would use the stock size . There would be a lot of extra volume anyway considering the added coolant capacity from the tube . Like I said if I don't like this front cooling set up with the triple fan shroud and full aluminum radiator it will get moved to the rear as it will be a ready set up just needing to be hung off the c hoop ...lol... I got to button it up and stop doing bs work on it so I can have it on the trail labor day weekend . I'd have more time but my tow rig needs to have the front end pulled apart since the Ball joints are moving up and down , so I have two new skf hubs spicer joints and some xrf ball joints to go in so I can continue to two like an asshole without losing a wheel .
Old July 23rd, 2021, 17:03
Cut the lexan and made windows to out back in.I screwed up my sheets I somehow grabbed the 3/16th sheet instead of the 1/4 and started my cut for the rear hatch window both sheets were sane length size just one thicker . The .188 is plenty thick but 1/4 would be better for that size window so it stays stiff I was lucky the 1/4 wasn't to thick to go in using the stock window gaskets...lol...they're probably bullet proof form a 22 at 1/4 ... The others are only 1/8th the bark gray shade 135 is about equal to my factory tinted rears they replaced. Now I need to re mask and paint the fender wells black after the over spray as I only covered the tires and struts so I have green speckles on the black I was going to line the boat sides but that seems like it will grab too much so I'll just use steel it on them again . Next weekend = paint radiator /trans cooler then the tow rigs maintenance and I get to go drive over stuff for Labor day weekend . I haven't decided on keeping the middle finger hood vents or doing a set of hyline louvers I think the middle finger louvers are too small I may put them on my trailers ramps for tail gaters .
Old July 24th, 2021, 18:19
Kittrell's Avatar
Kittrell Kittrell is offline
Headlight harness repair today. Annoying it takes a few hours to fix something someone destroyed in a few seconds. Rather than stripping down the headlight pigtails for his LEDs, he spliced directly into the main harness.
Old August 7th, 2021, 19:55
Fred's Avatar
Fred Fred is offline
I changed the oil!! Because the engine mount bolt hits the filter when upright, it was installed sideways, which necessitates removing the adapter to get the filter off. Getting old, couldn't get the beotch back on myself, had to have Zac hold it above, while I got the bolt in below. Did manage to install upright this time. LOL.
[Q. Why do the British drink warm beer?
A. Lucas wires their refrigerators too.
Old September 16th, 2021, 19:51
Fred's Avatar
Changed a windshield wiper.
Old September 20th, 2021, 23:41
Hypoid's Avatar
Hypoid Hypoid is offline
Added coolant this past weekend.
I was driving up a nearby canyon, trailer in tow, when the temp gauge hit the "ANGRY" zone. Stop, observe, add about a gallon of 50/50 coolant: Life is good!
On a side note, the fall colors should be good this coming weekend.
The Lost Boys' motto: We don't know where we are going, but we'll be there for awhile...
Old September 21st, 2021, 00:33
Calvin Bnvds Calvin Bnvds is offline
I can't wait to sell Black Friday this year as I finally bought a set of Nitto Ridge Grapplers. I am so excited about receiving this order and putting it on my vehicle.
Old September 24th, 2021, 05:35
Cerberus Cerberus is offline
Changed my front brakes (upgraded to ceramic, MUCH better stopping).
And next I need to find out what's making a growling noise from the rear when the driveline is freerolling off-load.
Old October 4th, 2021, 07:50
old_man's Avatar
old_man old_man is offline
Just put a set of BFG MT 35x12.50x15's on to replace the ATs. ATs are out of stock across the US. The MTs are fairly loud above 80mph and tend to wander a lot more.
I just finished front and rear brakes. I am trying to wrap up my full width Dana 44 build for the rear. I am waiting on my axles.
Anybody got a Dana 44 Detroit laying around? ha ha
Once finished, I will be pulling my regular width Dana 44 with Detroit and selling it. I would like to keep it together rather sell pieces.
I am installing a cool down timer on my fan as well.
Tom Houston - Former Colorado Chapter President, current Treasurer , Terminal Adrenaline Junkie, and Rocket Scientist
Loveland, Colorado My teardrop build
You're just jealous because the voices don't talk to you.
Old October 4th, 2021, 13:45
Kittrell's Avatar
Installing the new water pump turned into a much larger job. No internal damage luckily, limited to the timing cover.
Old October 7th, 2021, 07:53
old_man's Avatar
Too clean to be a Jeep.
Old October 8th, 2021, 15:35
repairs: front hubs & ujoints, and the water pump is starting to slowdrip.
upgrades: picking up an SYE kit from adams next month.
recent (this year so far): hood vents, mishimoto rad, trans cooler, coolant filter. (it was pumping mud through the engine)
Old October 12th, 2021, 08:10
old_man's Avatar
Nice Jeep.
Old October 12th, 2021, 14:13
Originally Posted by old_man View Post
Nice Jeep.
Thanks!
Old October 17th, 2021, 07:02
Added presidential support decals.
Rate This Thread:
Death wobble, the continuing saga RockTracXJ Modified Tech Discussion 11 June 2nd, 2010 06:46
Continuing the downward spiral of 4x4 design Lawn Cher' Non-Tech / Off Topic 28 April 19th, 2010 12:49
The saga continues... sams88 User Support, Questions and Suggestions 0 September 1st, 2007 23:08
1990 AC saga keeps going... cherokee4fun OEM Tech Discussion 14 June 13th, 2007 22:02
'00 Headers, and the continuing lack of them KCNMDE Modified Tech Discussion 0 August 8th, 2004 15:21
