Go Back   NAXJA Forums -::- North American XJ Association > NAXJA Chapters > Colorado Chapter
Colorado Chapter Discussion of Chapter issues. Please keep Tech Topics on the Tech Forums.
Thread Tools Rating: Thread Rating: 35 votes, 4.89 average. Display Modes
  #5416
Old June 26th, 2021, 11:35
Hypoid's Avatar
Hypoid Hypoid is offline
Re: What are you doing to your rig - the continuing saga
For my birthday, my Beautiful Bride got a minivan. I have been D-Ding the Accord.
Last weekend, I bought a can of wasp spray for the XJ.
The Lost Boys' motto: We don't know where we are going, but we'll be there for awhile...
Old June 28th, 2021, 07:48
ShoeterMcgav's Avatar
ShoeterMcgav ShoeterMcgav is offline
A faulty Ujoint job turned in to a new inside axle shaft, u joint replacement both sides, ball joints, C gussets (weld grind wire wheel clean primer and paint), new calipers, new pads, and full on tune up.
Hoping to get it out of the damn garage and into its natural habitat soon. Any Kelly flats or moody hill runs coming up?
97’ XJ lift lockers 35s mid arms 9"/hp30 trussed warn hubs wj brakes 1ton OTK 4.56s etc work in progress..
93zj BEAST 35s Claytons LAs 44/hp30 lockers bumpers headers etc $old
Old July 5th, 2021, 20:35
1-tonxj 1-tonxj is offline
Prepped and shot exo cage and body in predator green monstaliner . Swapped out all my old led lights for smoked LED lights and put in ebay's finest smoked LED head lights . Got a set of RGB rock lights to out on but they haven't arrived ... Yes it's a loud paint job. ...;-)
Old July 16th, 2021, 22:02
Kittrell's Avatar
Kittrell Kittrell is offline
Old July 16th, 2021, 22:16
smokeyyank smokeyyank is offline
Haha, really going down a rabbit hole.
Old July 16th, 2021, 22:46
Kittrell's Avatar
I can live with an ugly rig, but not THAT ugly. Every body panel that can be unbolted will be moving over. And for my OCD even found a 2004 Onyx Green grille (2004 color matched grilles are the business).
Old July 17th, 2021, 06:05
puttzer's Avatar
puttzer puttzer is offline
NAXJA Member #3000
Originally Posted by Kittrell View Post
Did they deliver it for free! You have tons a work to do!!
98 XJ 4.0 AW4 231
Old July 17th, 2021, 12:46
Kittrell's Avatar
Triple A
Old July 18th, 2021, 17:05
Kittrell's Avatar
Old July 18th, 2021, 19:09
Lookin good! Whatd the donor set you back? House the engine? Is it a 4.0 ho, or the 4.7 v8?
Old July 18th, 2021, 23:00
Kittrell's Avatar
$1k for the donor, 4.7 that needs a head gasket, low compression on cylinder 8 after a belt tensioner snap.
Old July 21st, 2021, 19:14
I just put on new hatch struts I got off eBay for $18 a pair . I've been using vice grips for years I remembered to order them when I got my cooling set up which I'll be putting in tomorrow and moving my trans cooler to the rear with the new fittings . If this front mounted triple fan set up doesn't do what I need it will work great if moved to the rear ... IMG_20210721_053122954_HDR.jpg
Old July 22nd, 2021, 12:04
Originally Posted by 1-tonxj View Post
I just put on new hatch struts I got off eBay for $18 a pair . I've been using vice grips for years I remembered to order them when I got my cooling set up which I'll be putting in tomorrow and moving my trans cooler to the rear with the new fittings . If this front mounted triple fan set up doesn't do what I need it will work great if moved to the rear ... Attachment 7396
Out of curiosity how are you plumbing the lines to the rear? I've thought about doing something similar with my MJ. read to use exhaust tubing to do it. Also are you using a high flow pump or stock?
Old July 22nd, 2021, 21:27
Possibly exhaust tube on the main section in-between the flexible fittings at each eend or heavy duty marine grade hose and somw kind of flexible fitting at each end ...could just be some of the old hoses I have . The stock pump works fine for this so no need to upgrade for that purpose . I think once I open up my grill area a bit moving the trans cooler and having the hood vented while running 3 e fans the under hood should be reasonable and the big mechanical fan gone so my worry of massive collimg system failure if it hits the radiator is gone so not much reason to move it from labor to reward ratio .
Old July 23rd, 2021, 11:47
Nice, I'll be interested to see how it turns out. Are you using a stock size rad or?
Rate This Thread:
Death wobble, the continuing saga RockTracXJ Modified Tech Discussion 11 June 2nd, 2010 06:46
Continuing the downward spiral of 4x4 design Lawn Cher' Non-Tech / Off Topic 28 April 19th, 2010 12:49
The saga continues... sams88 User Support, Questions and Suggestions 0 September 1st, 2007 23:08
1990 AC saga keeps going... cherokee4fun OEM Tech Discussion 14 June 13th, 2007 22:02
'00 Headers, and the continuing lack of them KCNMDE Modified Tech Discussion 0 August 8th, 2004 15:21
