Old October 17th, 2020, 11:49
RCP Phx RCP Phx is online now
Re: Rear Suspension Issues
Yes that's the one but you never did take a pic of the rig. By your description your springs aren't carrying the weight.
Old October 17th, 2020, 12:17
Evan03 Evan03 is offline
Mine rides alittle softer with longer shackles at .
My jeep rides pretty darn good with flat springs.
Got to thinking tht your bolt isn't hitting. With a flat spring it cn only get shorter under compression and droop. Its pulling the shackle away from your frame. Pulling twrds the front end.
Old October 17th, 2020, 12:19
Whats this mark from?
Old October 17th, 2020, 13:30
NOTNSUV's Avatar
NOTNSUV NOTNSUV is offline
You Guys ROCK!
Good find. The other side has 2, at each edge of the spring. Looks like a bit of a rub. Low miles on this setup, 50mi. off-road or might be more apparent.
Sent from my E6810 using Tapatalk
I'm a 'Do-it-Twice' kinda guy.. or..
Cross thread's better than 2 lock-washers
1999 XJ Sport 4.0L Black
Old October 17th, 2020, 14:08
NOTNSUV's Avatar
You Guys ROCK!
The rear bolt on both bumpstops snapped off, very difficult to drill bolt for ez out. No torch. Wondering if it would be ok to move both stops back an inch (or whatever the minimum I can get away with). Would just drill new holes and use 5/16-18 nurserts to mount.
Old October 17th, 2020, 14:23
Tim_MN's Avatar
Tim_MN Tim_MN is online now
Freakish Hand Strength
Since those leaf springs are saggy already, extended shckles will only accelerate the sagging.
Thr shackle hitting there. There are likely marks on the stock bumper bolts coming thru the rear crossmember also.
Those leaf spring look a bit saggy. IDK what they are rated at, but you may have better performance with leaf springs that have a higher spring rate, and/or higher load capacity.
Spring Rate: The amount of force it takes to compress the spring 1 inch expressed in lbs/in. The lower the rate, the softer the spring.
An add-a-leaf can increase the leaf spring carrying capacity, and restore some of the arch. . Adding a leaf to your leaf springs will raise the rear slightly depending on the donor leaf, and the recipient leaf pack on your vehicle, and may affect your ride to feel more rough or stiff.
Go ahead and slam the liftgate down on a blanket, and see how long you are laughing.
Old October 17th, 2020, 14:31
TRCM's Avatar
TRCM TRCM is offline
Same for the shackle hitting the bumper bolts.....
Old October 17th, 2020, 14:52
NOTNSUV's Avatar
You Guys ROCK!
No factory bumper (JCR) but will look more closely for any interference.
These are OME from DPG and he told me the ride would be superior. P/N on the spring is CS033R but doesn't indicate 'A' or 'B' or whatever. Should be HD.
I'm willing to redo the whole spring setup but should figure out what's happening here first I suppose. I did mark the shocks at normal stance, full extend and full compress so when things go back together I can flex it and see where it's at. Also pulled the three 1/2" bump stop spacers off. The passenger side, with a bumpstop, had register marks from the bump on the spacers.
Had a pretty good load in the back including, JCR swing away spare tire bumper with high-lift and 2 rotopax mounted. Plus, a load of recovery gear, fluids, etc. in the cargo area. That's what I want to carry when I get back out there so need the rear suspension to handle that.
Appreciate the patience and input.
Old October 17th, 2020, 15:07
NOTNSUV's Avatar
You Guys ROCK!
Only pic I could find with this setup. Yup, bit of a grade. Not sure if the full load was in the back.
Old October 17th, 2020, 16:09
NOTNSUV's Avatar
You Guys ROCK!
The one factory bumpstop is 3". Aftermarket in hand are 4" and looks like too much. Only 1.5" from spring to stop while sitting on stand under the axle. Man, I hope I learn something through all this.
Old October 17th, 2020, 17:29
TRCM's Avatar
You can remove spacers from the bump stop plate.....
Old October 17th, 2020, 17:44
NOTNSUV's Avatar
You Guys ROCK!
Already did that. 4" bumpstop, 1.5" clearance to plate mount w/o any spacers.
Old October 17th, 2020, 20:27
TRCM's Avatar
Well, at 3.5" I wouldn't even use those plates.......
I'm @ 3.75"- 4" of lift on mine, running 32" tires on 17" moabs....and I do have an extended bumpstop up top, but still no plate, just the stock configuration.....
Old October 17th, 2020, 20:33
NOTNSUV's Avatar
You Guys ROCK!
Right on! 3.5"/33s/trimmed fenders with Rusty's steel. Thanks.
Old October 18th, 2020, 07:00
Tim_MN's Avatar
The factory bumper bolts are very likely hitting the shackle or spring eye, they are all trimmed flush to head of the weld nut on my XJ. The leaf spring eye bolts are installed incorrectly, the threads should be pointing out.
Bumpstop length is determined by flexing the suspension until the tires make unwanted contact. The bump stop plates on your axle will probably make your bump stops somewhat custom and they will likely need to be shorter than extended bump stops using the stock locations/configuration.
An add-a-leaf will be the simplest and lowest cost method to add some load capacity and some additional rear suspension lift.
My 2000 is more or less level with all my off-road gear, bumpers and skid plates, tools, and spare parts.
Rear Suspension issues XJwheelman Modified Tech Discussion 7 September 27th, 2013 04:36
suspension issues JoeyBottles Modified Tech Discussion 5 July 25th, 2012 17:46
Front Suspension Issues mavrick Modified Tech Discussion 12 December 23rd, 2010 22:09
Front suspension Issues .... hemiriffic Modified Tech Discussion 4 March 15th, 2010 14:48
Suspension Issues... Grant H. Modified Tech Discussion 8 April 4th, 2007 18:38
