Old August 20th, 2020, 21:54
Chillipepperlq9 Chillipepperlq9 is offline
8.25 gear wear pattern
Struggling a bit with my gear set up, has anyone had a pattern like this? Looks like the drive side is pretty high on the toe. How do I correct this? I can't find a lot of literature on this patter and I used the pinion depth tool to calculate the right shims for pinion depth. See the pictures below.
Sent from my SM-G965U using Tapatalk
Old August 21st, 2020, 06:45
RCP Phx RCP Phx is offline
Re: 8.25 gear wear pattern
The first thing you need to do is pull a good pattern. You need to apply more pressure on the gears and get a pic of both the drive and the coast side.
Old October 14th, 2020, 18:48
Well I played with it a little today, I started at .025 then moved up to .035 and .0455 eventually to see how it changed. All at around the same backlash of .007. You can look at the pictures but what is driving me crazy is that it seems like the Drive side doesn't change from the top toe corner.
I used a pry bar to apply pressure.
Any thoughts?
Sent from my SM-N986U using Tapatalk
Old October 14th, 2020, 19:27
Definitely not enough resistance on the gears, you got to check back-lash on clean gears. I don't see where your anywhere close.
Old October 14th, 2020, 19:30
Btw, how much pre-load are you using?
Old October 14th, 2020, 19:39
Pinion bearing 15 inch pounds, 70ft pounds at the carrier bearing. Yeah I am definitely doing something wrong, ill recheck everything and try again. Will report back.
Old October 14th, 2020, 20:06
denverd1 denverd1 is offline
Is this a pattern? Looks like you painted the gears and took pictures
Old October 14th, 2020, 20:08
Haha thanks I try to be a bit artistic, no but seriously I am trying to every tip and everything that is out there. I do admit I have no experience doing this but you can only learn one way. I appreciate all the help
Old October 14th, 2020, 20:09
Keep on bro. Just keep keepin' on
Old October 15th, 2020, 10:26
WAZZUXJ's Avatar
WAZZUXJ WAZZUXJ is offline
SoCal_XJ FB
Stuff a rag against the ring gear to create some drag so you can get a better contact pattern.
Are these new gears?
Old October 17th, 2020, 08:37
XJAbroad XJAbroad is offline
Also dilute your marking compound down some with a little wd40 or equivalent and apply thin layers. No need to cake it on.
Old October 18th, 2020, 08:41
4x4JeePmaNthINg's Avatar
4x4JeePmaNthINg 4x4JeePmaNthINg is offline
as said is these new gears?
what did you use for a starting point and how did you determine this?
once you find out what is too much and too little backlash you can adjust accordingly. same with pinion depth. It takes some time to go to both ends of the spectrum and narrow that down. stay with it!
Reusing gears with bad wear pattern? zith Colorado Chapter 5 October 17th, 2014 12:01
D30 gear pattern check, first gear install P1atinum Modified Tech Discussion 19 April 7th, 2011 16:19
Explain bearing wear pattern cgmrdc OEM Tech Discussion 5 February 19th, 2008 15:55
Gear guru's...gear pattern check... freerider15 Modified Tech Discussion 21 November 21st, 2007 20:21
rod bearing wear pattern - please help - long but urgent Micha OEM Tech Discussion 12 April 22nd, 2006 21:02
