Old June 25th, 2020, 03:29
Down under Down under is offline
Universal joints, front
Hi, pick your brains please!
Got a 97 XJ, and soon to put new hubs in.
(No abs) standard D30.
So I think ... what the heck, axles are out. So I might as well put new "U" joints on the front axles.
Plus new upper and lower joints.
Make a day of it!
BUT... are the axel "U" joints the same part as the front drive shaft " U" joint?
The Jap Toyo brand are available here in Australia at a reasonable price.
# K5-13 XR ?
Do I just I just need 3 of the same to do the front end up?
No front cardinal shaft ( think) !
Thanx in advance!
Old June 25th, 2020, 03:52
Tim_MN's Avatar
Tim_MN Tim_MN is offline
Freakish Hand Strength
Re: Universal joints, front
The XJ Cherokee D30 axle u-joints are not the same as the driveshaft u-joints. The auto parts store should be able to cross reference the Spicer part numbers. 1995-2001 should have the larger 5-297x u-joints.
People are dumbfounded when I tell them I know how to change the spark plugs on a car.
Old June 25th, 2020, 04:04
Doh! My ignorance is now public! Ha!
So the spider ref part number is....#?
Old June 25th, 2020, 06:04
devildog0's Avatar
devildog0 devildog0 is offline
I think TimMn got his #s backwards. You need a 5-760X u-joint.
Here they are on Amazon.com.au. Looks like they get imported from us.
https://www.amazon.com.au/5-760X-Spi...8&sr=8-1-fkmr0
I didn't have any luck digging up a cross reference chart for Toyo joints though.
1995 XJ Country/4.0L/AW4/231/UpCountry Suspension
2004 Suzuki DL650 VStrom/1978 Suzuki GS1000E/2003 Yamaha TW200
1982 Suzuki GS850G (barnfind project)
Old June 25th, 2020, 06:25
Cheers guys!
With cross referencing jeep parts in oz, it seems there is like a copyright on them.
You just end up with dumb blank looks!
As if they don't get a hit their computers!
Painfull!
And I think eBay should force sellers to disclose country of Origin!
Sick of Chinese CRAP!
Old June 25th, 2020, 06:54
RCP Phx RCP Phx is offline
Try these folks, they seem to have had them available in the past.
https://www.sbroffroad.com.au/Axle-P...y-Axle-U-Joint
Old June 25th, 2020, 07:01
Tim_MN's Avatar
www.rockauto.com is great for finding alternate part numbers. I think they ship worldwide also.
As noted above, 5-297x u-joints are discontinued and can be replaced with 5-760x.
Old June 28th, 2020, 22:51
Thanks guys!
My rig has the 8.25 Chrysler.
Are the 4 uni joints all the same on the prop shafts front and back?
Did any jeeps come out standard with a double cardan on the rear that can be swapped into 97 XJ ?
Old June 28th, 2020, 23:06
Been bloody 20 years since I've fitted a set.
As there any issue with taking too the old uni and just cutting it twice just inside the yolk?
All care of course, but would it make it easier to press out ?
Old June 29th, 2020, 06:01
devildog0's Avatar
Originally Posted by Down under View Post
Thanks guys!
No XJs came standard with a rear double cardan shaft. Many folks use a front drive shaft in the rear when doing a SYE kit.
Sent from my SM-G892A using Tapatalk
Old June 29th, 2020, 06:04
devildog0's Avatar
https://www.amazon.com.au/dp/B082LQW..._YAE-EbMZDHJW7
Worth the money for several jobs in an XJ
Old June 29th, 2020, 16:06
Black1990jeep Black1990jeep is offline
Go with a known quality name brand. Non greasable i.e. permanent lubed joints are considered strongest verses greasable if all other things same. The grease passages can weaken the cross piece.
Full circle snap rings are preferred to the stock C rings. You can buy these. However stock axle forks will need bit of grinding to clear the full circle snap ring, easy job. Way it is, the stock with fork not cleared all around, they had to use the C ring, but that C ring can walk around, and it can walk right out of its groove as it walks up the metal that will be ground away to fit a full circle full circle snap ring.
Spicer is a good brand of U joint. it was recommended to me by 4wd people as a good brand, I run it, and have done rock crawling with 33x12.5 tires, U joints have not failed me.
Sure you may find a half price copy, or no name joint, but if it fails, its a lot of work to replace, and failure can destroy an axle, negating any savings of low purchase price of the imitation U joint. Don't go cheapo here!
Locally, I dont know what are good brands available to you, so ask a local 4wd shop, or 4wd club.
My friend lost a cup on his axle U joint when the C ring walked out. The axle fork got bent when this happened. So he had to replace the axle, he clearanced his axles with a small grinder and fit full circle snap rings on both left and right axles, That never will strand him again.
So consider...
a.. Use non greasable joint.
b. Use name brand for sure.
c. Use full circle snap rings.
Cheers from America! Australia is a real nice place, nice people. Been there, so I say that with certainty.
Are there a lot of XJs down under? Do you drive a US built xj or other? Right hand drive, correct? What is the xj scene like? I know Toyotas where big in Australia a long time ago, saw a gazillion of them. There was an industry of converting American cars, to right drive, big market for importing muscle cars and classics, but unless they are a museum piece, they where converted. I saw dashboard assemblies, for Mustang, Camero, Malibu, etc... even pick up trucks like Ford or GM. These dash assembly's were made with right hand drive offered for sale as conversion kits, so after conversion it looked like it was factory made right drive. Seemed to be a good sized right drive conversion industry for the car hobby market.
Old July 2nd, 2020, 02:13
Thanx heaps guys. I got some spider joints delivered today, plus a pair of the better outer seal kits.
$220 au !
We call it jeep tax here!
Yes SBR Off road where very helpful.
Going to hold off for a week till I can afford the ball joint kit.
$340au...(terraflex) do it all in one hit.
Will hit that link on tail shafts shortly.
Yet to catch up on lingo of "SLE" etc.
Still unsure if the two front drive U joints are the same as the back 2!!!!
Sadly not too many Xjs I see on the road these days here in oz.
My 97 "sport extreme " (badged as here) has the Chrysler 8.25 in it!
Very rare diff here. So very hard to source parts!
Zero open centers I know of out here. Had to import one to fit a Spartan locka..$$$$$
+ it's illegal here in Australia to have them fitted!!!!
(Unless you can disengage it from inside)!!!!
A panel beater in Sydney gave away the proffession to convert LHD to RHD 30 years ago.
Doing well.
Obviously some things are back to front to your models.
Alternator is up top on RHD side ( mods needed to get to #1 plug but)
Jeep went down here in the early 2000 models, but picking back up. See a few newer ones now.
Thank God you guys put stuff up on YouTube!
Big help!
universal joints jamesbtaylorjt Modified Tech Discussion 2 October 20th, 2011 08:08
Universal Joints mknack Modified Tech Discussion 8 October 19th, 2009 11:17
Universal Joints Milk Dud Modified Tech Discussion 15 August 7th, 2009 12:12
Universal Joints on axel shaft fdsa487 Modified Tech Discussion 5 June 11th, 2006 16:12
Front Universal Joints GoalPoster OEM Tech Discussion 3 February 24th, 2005 20:49
