Old November 24th, 2019, 07:02
Heavyopp Heavyopp is offline
Re: Help picking a MIG frame welder
Your 1st project is going to be challenging for a newb welder ó out of position, dissimilar thickness, hard to see
What helmet are you planning? Donít go cheap ó it does make a difference
Old November 24th, 2019, 12:05
Skwerly Skwerly is offline
I run a Miller 140 with flux and it has more pop than you'd think. That being said, I'd run 220 if you at all can. Good advice. Hobart/Miller have always been my gotos but I wouldn't hesitate to run a Lincoln or a Forney or Esab, etc. Steer clear of HF stuff -- not because they are inherently bad, but because when it comes to welding, in my opinion, you want to count on those welds holding.
Old November 24th, 2019, 12:19
RCP Phx RCP Phx is offline
I would also recommend a 75/25 gas(co2/argon) mix for the thickness of the metal.
Old November 24th, 2019, 14:16
denverd1's Avatar
denverd1 denverd1 is offline
You use different gas for thick material? Real question is will he be welding indoors or out. if outside with any wind, OP don't waste your money on gas and regs.
I picked up a 110 volt Forney to learn with. And will be using it for stiffeners vs the 220v Hobart I recently acquired.
Buy once, cry once. get a good machine that can do thick stuff and be turned down for thin stuff like stiffeners/frame rail. Don't be like me and end up with 3 welders.
Chili Pepper '98
4.5" lift, locked on both ends, 33s
10K winch and a lot of skinny pedal
Old November 24th, 2019, 14:27
Different gases are used for different penetrations, the 75/25 is actually used for the thinner materials.
Old November 24th, 2019, 15:28
denverd1's Avatar
maybe. never heard of anyone running a different mix
Chili Pepper '98
Old November 25th, 2019, 23:16
abc_was_here abc_was_here is offline
I just used my Eastwood 175 mig to do my frame stiffeners and it worked great. If you really wanna stay 110 Eastwood makes a 135 that would be enough for frame stiffeners. Its a very affordable welder as well. A Lincoln 140 would also do the job and is a good stater machine.
Old December 1st, 2019, 14:43
Evan03 Evan03 is offline
Esab 215 miller 215. Both very good welders.
https://bakersgas.com/products/esabr...pkg-0558102240
I'll probly end up replacing my hobart 180 with one.
I would advice against buying a 110v only unit.
Everlast has some good welders that cost less than the name brands. That will spank any 110only unit.
https://www.everlastgenerators.com/p...ower-i-mig-200
Youl get quite alot for your money by buying everlast but youl only have online support.
This one is a sweet little welder 120/240 mig stick tig plasma cutter all on 1 unit.
https://www.everlastgenerators.com/p...werultra-206pi
The miller 215 doesnt even include the stuff needed for tig it's also now debatable if miller welders are any better than the welders shipped in containers from over seas.
Most likely the welders by miller are cheap China welders in the 1500 and under range.
But sometimes customer support comes with a price tag.
Good luck and have fun with whatever you get. Welding is a very enjoyable hobby.
Ohhh heres the esab wire only.
https://bakersgas.com/products/esabr...der-0558102436
Old December 1st, 2019, 20:05
country2 country2 is offline
Just wanted to add when I welded in my pans I purchased the Esab rebel EM215ic. Its dual voltage and works great. As others said buy one that can also do 220v and don't go cheap...as in a cheap made one. Mine had a rebate think out the door was maybe $800. Buy a good helmet and I have noticed a differance between using a good brand wire verses cheap ones...
Old December 1st, 2019, 20:29
Welding machines we can debate on all day long.
110/120 only machines in my opion just dont need to be doing much jeep type welding unless its body work.
Theres definitely a learning curve. Curve will take longer with under powerd machine vs a machine that's very capable.
Youl find all kinds of things to build ounce you get into the learning curve. with the wrong machine you may just become frustrated.
A good machine will help turn you into a rockstar
Old December 2nd, 2019, 09:26
bajabronco bajabronco is offline
Not to hijack the thread, but I was looking at some of the cyber Monday deals today and saw the Eastwood 250 Mig on sale, does anyone have first had experience with one? Seems to have a great duty cycle and good warranty-https://www.eastwood.com/mig-250-welder-eastwood.html
Old December 2nd, 2019, 12:54
Rockwood Rockwood is offline
I bought a Vulcan welder May 2018, quick review here:
https://www.pirate4x4.com/forum/shop...ar-vulcan.html
That being said: why 110V? Does your garage have a 220V dryer plug? I made an extension chord with 8-3 stranded connected to a dryer plug male on one end, and the NEMA-30 female on the other end for the welder.
Old December 2nd, 2019, 12:56
BTW, tried using 110V for an extended period of time yesterday welding some 1/8" mild steel. Got through about 6 welds before the breaker popped. Annoying.
Most pure 110V welders have weak feed motors and lower duty cycles so they don't pop breakers all the time. Most dual voltage welders just pop breakers on 110V for anything heavier than 14g.
Old December 11th, 2019, 20:02
JungleJames JungleJames is offline
Hey Y'all - Update
I ended up picking up a local barely used Hobart 210 MVP. It's transformer based so it's pretty heavy but is working really well on 120V and mixed gas setup.
Used I paid $600 then picked up a full tank and a Jeep load of Horrible Freight stuff; Vulcan cart, steel table, two Bauer grinders, cut off wheel pack, wire wheel pack, flapper wheel pack, hammer, welders pliers, gloves, and a impressive Vulcan ArcSafe hood. All for roughly the same price of a new Miller 211.
I'm off and welding! Thanks for all the advice
Old December 11th, 2019, 20:06
Anak's Avatar
Anak Anak is offline
Stranger
Congrats.
Enjoy your new toys.
BTW, if you end up shopping at a steel supplier who has abrasives for sale too, don't be a afraid to pick up some of the stuff they carry and compare it to the HF stuff. You may find that for a 15-20% increase in price you get a 100% increase in cutting life.
Baby it's cold outside.
Mini-Welder 115v welder/carbon torch, Front OEM skid and other stuff Bent SoCal For Sale 9 January 22nd, 2016 17:17
Picking up a TJ IcedXJ Non-Tech / Off Topic 9 August 30th, 2006 21:40
Would you consider picking up another XJ? johnlv6 Non-Tech / Off Topic 18 May 30th, 2006 15:44
Need help picking up XJ JeepFreak21 Sierra Chapter 17 July 8th, 2005 12:45
ready welder/century welder/portable welder? Redcbr007 Wanted: Private Party Only 1 June 6th, 2004 23:01
