Old August 30th, 2019, 08:29
paulhead's Avatar
paulhead paulhead is offline
I overtighten $#!t
Bad gas mileage 10-11 MPG
I know a common problem but wouldn't mind some input. 1992 4.0 AW4, 4.88s, 35s. Fuel lines and rails were redone before sold to me so it could pass smog which it did easily. I've had jeeps before and I know it shouldn't be this bad. One thing I've noticed is it's shifting weird likes it's floating between gears once in a while. It was doing this really bad before but I replaced the TPS and it's normal now but still doing it very slightly.
“Lead me, follow me, or get out of my way. ”
-Gen. George S. Patton Jr.
Back at step 1, bought a YJ, an XJ going under the knife....
Old August 30th, 2019, 08:41
RCP Phx RCP Phx is offline
Re: Bad gas mileage 10-11 MPG
What have you done to check the motor(comp check, vacumm, spark plugs, coil, wires, and timing)? I'm getting 16mpg with a high hp stroker!
Old August 30th, 2019, 09:07
paulhead's Avatar
I overtighten $#!t
No codes, plugs and wires are fairly new, I guess I could check for vacuum leaks with starter fluid.
Old September 4th, 2019, 09:58
Scrubber3 Scrubber3 is offline
Torque converter?
Old September 4th, 2019, 10:25
Tim_MN's Avatar
Tim_MN Tim_MN is offline
Freakish Hand Strength
Check the basics, tune-up, comp, vac leaks, manifold leaks, and then check the O2 sensors. Nearly all XJ's have or will have a cracked exhaust manifold.
Go ahead and slam the liftgate down on a blanket, and see how long you are laughing.
Old September 4th, 2019, 10:34
IslanderOffRoad's Avatar
IslanderOffRoad IslanderOffRoad is offline
hows the power feel?
John V.
RRC VP
01 XJ Sport 2 door 5spd/4WD- 4" lift, Rubi wheels/tires JCR bumpers/sliders, armor, Rubi 44, Ford 8.8, 4.56's, ARBs.
Old September 4th, 2019, 13:11
Black1990jeep Black1990jeep is offline
dragging brakes? does she roll easily in neutral?
Old September 4th, 2019, 14:33
paulhead's Avatar
I overtighten $#!t
Originally Posted by Scrubber3 View Post
Torque converter?
Interesting, not engaging 100%?
Good power
yeah, thought about brake drag too, not noticing it.
Old September 5th, 2019, 04:55
cruiser54's Avatar
cruiser54 cruiser54 is offline
Ever pulled the distributor cap and looked inside?
Don't use starting fluid to check for vacuum leaks. It can travel whereas carb cleaner and brake cleaner stay a liquid much longer.
A common issue is loose intake manifold bolts. Snug them up as needed.
The vacuum line from the intake manifold to MAP sensor is critical. any slight leak and the fuel mixture goes richer.
Old September 5th, 2019, 11:06
EvaB99XJ EvaB99XJ is offline
Regarding the transmission still shifting funky after the TPS swap - has the transmission fluid and filter been changed recently?
Old September 5th, 2019, 12:29
old_man's Avatar
old_man old_man is offline
Run a can of BG44k through the fuel to clean out the carbon and the injectors. Old clogged injectors is one of the most common things for crappy gas mileage.
Tom Houston - Former Colorado Chapter President, current Treasurer , Terminal Adrenaline Junkie, and Rocket Scientist
Loveland, Colorado My teardrop build
You're just jealous because the voices don't talk to you.
Old September 5th, 2019, 14:06
ehall's Avatar
ehall ehall is offline
torque converter clutch not engaging will do it for sure, since without the clutch you are relying on hydraulics alone. if you feel like the trans is shifting weird I would probably start there.
check for fuel leaks / damp fuel lines (no kidding)
use the key trick to pull codes and see if anything there that didn't trip the CEL
are you running a 180 or 165 thermostat? the computer tries to get the engine temp to 195 by running a rich mixture so that the cat converter works efficiently, if temp stays low the computer will forever be dumping unnecessary fuel. O2 sensor can do it too but not usually that aggressive
my '91 beater rebuild
Old September 5th, 2019, 22:23
paulhead's Avatar
I overtighten $#!t
No codes, pretty sure I'm running a 195 thermostat, it's running at operating temp.
Old September 13th, 2019, 11:47
blu3fan's Avatar
blu3fan blu3fan is offline
Ive had my intake man fail to seal multiple times. I would start by using a propane torch off. and searching the engine bay.
or you could use smoke.
whatever floats your boat.
if its a vacuum leak it will show.
blu3fan's Avatar
otherwise fuel pressure test.
then check spark.
Why is my gas mileage so bad walkerja191 Modified Tech Discussion 33 January 6th, 2009 20:52
gas mileage mitsumotors Modified Tech Discussion 61 December 27th, 2007 19:33
Better mileage icebergmedic Modified Tech Discussion 6 November 21st, 2007 12:23
Where the gas mileage go? balor OEM Tech Discussion 5 November 2nd, 2005 16:07
No cat mileage ParkCityXJ Modified Tech Discussion 8 December 28th, 2004 23:10
