Old November 30th, 2017, 05:59
1995xjrd 1995xjrd is offline
96 no start after changing the battery
My Cherokee battery was over five years old and wasn't cranking over anymore, so I went and brought a new one.
Put the key in and now I don't hear the fuel pump turn on.Try replacing the fuel
pump relay and that didn't work. Any suggestion on what I should check?
Thanks in advance, Chris
Old November 30th, 2017, 15:24
JeepNoob JeepNoob is offline
Re: 96 no start after changing the battery
Any other electric stuff not working? There's a fusible link wire (or there SHOULD be, at least) at the front of the engine fuse box between two studs. If multiple things aren't working or don't have power, I'd check that first.
Old November 30th, 2017, 21:14
lawsoncl lawsoncl is offline
Had that issue with a 93 ZJ after having the battery replaced. Turned out they squished the wire and connector that was next to the battery. The Jeep would die when it hit a bump, I'd tow it home, and it'd be fine once it hit the driveway. It finally stayed dead so I could chase it down and found out that all the computer and sensor grounds merged together into that single wire.
Old December 2nd, 2017, 09:23
Took the cover off the front of the fuse box and there are just two wires held down by a nut, no fuse block. Checked on a different Cherokee and the same thing, no fusible link.
Going to change the positive cable to see if that does anything.
Thanks again for the help. I need to get it running again before it snows.
Old December 2nd, 2017, 10:15
Do you have a meter or a test light? That would make testing power cables and such much quicker instead of ripping and replacing at random. Measure various points while trying to crank to see if you have voltage where you're supposed to and no voltage where you're not (ie, ground wires).
If you have power to other things while hitting the key to crank, it's probably not the power cable to the fuse box. I don't recall whether the starter has it's own cable from the battery to the solenoid, or whether the feed came off the stud at the fuse box.
Old December 2nd, 2017, 13:21
It's weird that not I am getting no power to the fuel pump. It cranks and all the other electrical components work but I don't hear the pump turn on and there is no fuel in the rail. How do I check the wiring to see if I'm getting power to the fuel pump?
Old December 2nd, 2017, 14:28
You tried swapping out the ASD relay? That will kill spark as well.
Old December 2nd, 2017, 22:39
Dragonslayer Dragonslayer is offline
"Took the cover off the front of the fuse box and there are just two wires held down by a nut, no fuse block. Checked on a different Cherokee and the same thing, no fusible link."
The fusible link is not a "fuse block" - it is incorporated within the 10 gauge green cable
at the front of the Power Distribution Center (PDC) - held down by a stud and nut.
The green cable emerges out of the PDC and is routed underneath the PDC.
You'll then see a plastic splice there. The cable then disappears into the wire harness.
It then emerges from the wire harness as a 6 gauge Black/White wire that terminates at the back of the alternator.
Disconnect the fusible link at the PDC, and the alternator, and then test it for continuity.
Of course, you'll want to disconnect the battery before doing any of this.
Old December 5th, 2017, 06:54
To test the fusible link is the cable going down to the alternator connects into a black plastic box located on the back of the alternator the one i should disconnect?
Old December 5th, 2017, 13:29
I disconnected the black wire that comes out of the plastic black box and is grounded to the back of the alternator and used that wire to test the fuse and there is no continuity.
Did I use the right wire?
Old December 11th, 2017, 13:49
Checked the fusible link and it has continuity. I can't seem to figure out how I don't have power to the fuel pump? Anybody have any suggestions on what to check next?
Thanks, chris
battery died, now crank no start ehall OEM Tech Discussion 7 February 9th, 2011 18:16
A short kills my Battery right after start up. it will only start with a jump help! paxj1112 OEM Tech Discussion 4 June 30th, 2007 20:22
Alternator not changing battery? BrokenXJ OEM Tech Discussion 2 February 23rd, 2004 20:01
disconnect battery when changing oil? dogtired OEM Tech Discussion 8 February 2nd, 2004 07:58
dead battery now no start onetallmj OEM Tech Discussion 2 August 18th, 2003 22:36
