Old November 18th, 2017, 11:33
Intellect Intellect is offline
Re: I can not find the bmw checkvalve for pre 97 cherokees.
Originally Posted by comanche91 View Post
THIS one works fine.
Talking from experience?
Sent from my Moto G (5S) Plus using Tapatalk
Old November 18th, 2017, 11:35
The thread looks so messed up on my end on ny my phone, do you have a link? Is that the amazon link or the bmw part link? It just shows a stock image on this phone.
Old November 18th, 2017, 11:38
Green Mesa XJ's Avatar
Green Mesa XJ Green Mesa XJ is offline
Itís a ebay link, this is the description :
5/16", 8mm ID Inline Fuel Check Valve WITH CLAMPS for Gas, Water, Diesel, Oil
eBay item # 262633687270
Old November 18th, 2017, 11:39
Did you personally use this one?
Old November 18th, 2017, 12:22
comanche91's Avatar
comanche91 comanche91 is offline
I did use it, yes. Spliced into the supply line near the tank at the first rubber line section above the right axle on my MJ. It helped hold the fuel pressure better overnight, held to ~20 psi in the morning. It's still inline.........
EDIT: Damn - didn't realize the check valve pic was so huge. Mods, please delete if possible.
Old November 18th, 2017, 12:34
So any 5/16 check valve should work? Im going to go to a part store if so local.
Old November 18th, 2017, 12:35
Prob put mine right there. Engine side of filter.
Old November 19th, 2017, 10:19
Installed it... Fuel still bled off fast, was puzzled af. Uninstalled. It already went bad...
Old November 19th, 2017, 10:28
comanche91's Avatar
You can also be losing fuel line pressure at the regulator and/or via leaky injectors.
Old November 19th, 2017, 10:31
Ive been diagnosing this for weeks. I bounced back and forth a few times. So i put my gauge literally in the post filter line. So it was tank/pump.. filter.. gauge.
Old November 19th, 2017, 11:04
comanche91's Avatar
Try pinching off the return line to see if the gauge pressure rises. If not, it usually means the FPR has a bad diaphragm and/or leaky o-rings.
Old November 19th, 2017, 20:50
As its running, that would cause so many issues id imagine lol
Old November 20th, 2017, 04:58
ehall's Avatar
ehall ehall is offline
I tried using the ebay check valve once, they suck ass. They are just a small spring holding a plate, and the pressure from the pump is much higher than the spring pressure, so the pump just blows the plate and spring out of the way.
After that I bought a nice heavy brass check valve from McMaster and some flared end fittings https://www.mcmaster.com/#7768k53/=1ac4uo8 I have been running it for a long time, its not perfect but it works well enough. Handles up to 500 PSI head pressure, only requires 1 PSI to open.
my '91 beater rebuild
FS: (2) 96 Cherokees XJsportG SEC For Sale / Wanted Forum 9 February 28th, 2014 11:06
Where to find police package Cherokees? 90Pioneer NorthWest Chapter 16 December 2nd, 2010 20:57
new guy not new to cherokees! rockhard4x4 Non-Tech / Off Topic 3 June 1st, 2009 19:07
87 & 94 cherokees builder For Sale: Private Party Only. XJ ITEMS ONLY 0 July 29th, 2007 15:34
Cherokees/Grand Cherokees different AW4's? XJZ OEM Tech Discussion 1 April 28th, 2005 10:11
