Old December 14th, 2016, 21:23
Smokehouse_83 Smokehouse_83 is offline
Re: Rear Axle options with a fron HP Ford 44.
You could order better axles for the Toyota axle with any bolt pattern. Pretty sure Dutchman will do about anything. I have 4:88's and 35's and it is perfect.
Old December 15th, 2016, 04:15
MoparManiac's Avatar
MoparManiac MoparManiac is offline
4.88s and 35s are perfect.
If you're running 35s, I'd stick with a D44 rear with chromo 30 spline shafts. Throw a lockrite in it and be done. D60 is a pretty large/unnecessary axle for 35s for the majority of people. If you were running 37s, my opinion would be different.
Depending on your front axle width, I'd try for a waggy D44 rear.
Old December 15th, 2016, 05:56
cal's Avatar
cal cal is offline
NAXJA Warranty Voider
You don't think that 58" is a little narrow for a rear?
Old December 15th, 2016, 08:00
Ghost's Avatar
Ghost Ghost is offline
Member Number 257
So it looks like the T100 is 66.75" wide. That is really close to the 44. Non c-clip 30 spline shafts third member type axle. 93-98 they were in production. Disk brakes. This might be a cheap solution if I can get 5x5.5 shafts.
http://www.drivetrainshop.com/Toyota...ndra_s/122.htm
"...I need to wheel to be rejuvenated to fix things to wheel. It's a vicious cycle, but I love it."
Rick Pewe Ed: Petersons 4 Wheel and Off Road
member since 3/05/2001
Old December 15th, 2016, 10:27
8" will laugh at 35-37's and there are a ton of locker options for them. Also the ground clearance is nice.
Ford 8.8 Rear Axle. 12bravo Sierra Chapter For Sale 14 February 15th, 2016 17:01
Question about 4.10 rear axle options VanDerKen OEM Tech Discussion 13 September 13th, 2011 19:30
Ford 8.8 Rear Axle For Sale RubiconExp.XJ For Sale: Private Party Only. XJ ITEMS ONLY 3 July 20th, 2004 04:03
Rear axle options XJ92jeep Modified Tech Discussion 9 March 21st, 2004 09:37
Options for rear axle shafts BrianG Modified Tech Discussion 7 July 3rd, 2003 08:58
