Old December 10th, 2016, 10:46
sinat01's Avatar
sinat01 sinat01 is offline
Re: SYE question
On mine I had to get a new driveshaft, the front ones are too short, but you can snag an adams offroad shaft either from them, or some ebay stores have them for cheap, I had mine within 4 days of ordering, and it was like $230 shipped
Also, I used 4* shims and the only vibes it gets is from the H&T style SYE, and I barely notice them, but you can do a t-case drop and maybe shim the rear axle and be fine to, just depends on how much more you wanna spend.
Old December 10th, 2016, 14:07
97xjsam's Avatar
97xjsam 97xjsam is offline
Re: SYE question
22" from center of the center cap to bottom of the oem flare on the rear and 21" on the front
Old December 10th, 2016, 14:15
97xjsam's Avatar
Re: SYE question
Just not wantin to do a TC drop. Think I'll save for the SYE. Would like to do the 2 low kit too but I would think that would be a bunch mor money...
Just
Emptied
Every
Pocket
Wheel Hub question/limp, poor handling question - been researching fishinpolejoe OEM Tech Discussion 3 December 5th, 2016 19:03
Brake Upgrade Question (with Transfer Case Drop BONUS Question) NateEnos Modified Tech Discussion 9 April 13th, 2011 14:41
Fuel System question, Electric Fan Question POSJ OEM Tech Discussion 11 January 26th, 2011 10:18
Super quick question before I head out the door to the Junkyard. 99+ intake Question. Plays For Jeeps Jeep Street and Performance 26 October 13th, 2008 06:25
98xj 4.0L high idle question code question rapom OEM Tech Discussion 4 June 27th, 2005 16:18
