    More Information - Join/Renew
Dana 30 Pattern Check
Blue xj 99
CT
Hello,
Could I get some feedback one my gear pattern. Its a Dana 30 HP with 4.56 gears. Ill post backlash and shim specs later. Let me know if this looks good or if it can be better.
That's not a read-able pattern, needs more pressure(load) on the gears.
ok, so I get to fine tune my pattern and this is what I got.
NRG= .0785
RG= .02055
BS=.008
Pinion shims=.059
Thanks for the advice. My pattern looks way better. This is the best I have gotten in a while. It looks close but I think it could be better. Let me know what you guys think and any suggestions.
NRG= .05590
RG= .04165
Pinion= .0355, Add .0204 for the baffle
Backlash= 10
Sent from my SAMSUNG-SM-N915A using Tapatalk
Tighten up the backlash and pull another pattern.
Ok so two pics are with a backlash at 6 and the last two are at 9. Let me know which one is better.
If you guys could chime in that would be great. Jeeps been out of commission for a while and the gears are the last thing needed to get done.
Neither look perfect but your "patterns" are hard to read. What's your run-out on the ring gear? I always check that, with a full turn pattern under as load with as much pressure as I can apply. It looks like it wants .007-8" backlash!
What do you mean by run out?
Ring gear/carrier side to side movement(as in changes/variations) in thousandths! That's why I recommend a full ring gear pattern check.
Also don't try to read the drive and coast side at the same time.
I'll try to get better pattern readings. Is the runout measured without any shims or with the amount of shims that are currently on the carrier?
It's measured with what ever shims you have installed that you are checking the pattern on!
I should add that the run-out has nothing to do with any shimming, it's caused by the machining tolerances in the carrier and the gears and even your installation. Do you deburr the carrier? Did you stone and deburr the ring gear? Did you heat the ring gear and chill the carrier before installation? What brand of gears did you buy?
I didnt do any of those things. They are motive gears and I made set up bearings which is what I'm using now. Made sure to use the different carrier for the new gear ratio.
Do shops really do these things? -- Kinda sounds like using distilled water in a coolant system -- we all know it's the right way but find me a shop where you have ever seen it done...
If your able to measure the backlash, you can still measure the run-out. The important thing is the pattern!
No, but good installers can read a pattern and know what to do with it !!!
