Got robbed by the junkyard again. Picked up a 29 spline 8.25, wj knuckles & brakes, 2wd hub for spare in case I break a shaft. Started on a set of sliders and did some paint/clean up on the 2 door
Sent from my SM-G981U using Tapatalk
Yep that was me! Most comanches I've seen for sale lately are 2wd but sounds like you have most the parts to convert one. Did you say you needed an xj trailer hitch? I realized I have one sitting around if you want itWas that you and your dad I talked with at the junkyard yesterday?
Today I went back to the one across the street and picked up a 231 t-case, an 8.25, and a D30 off a 98. Now if i can just find a Comanche to finish my collection. Hmmmm.
Glad to hear you found one. For me its just a waiting game on parts. As soon as I get my orders from Cav Fab and IRO ill start stripping my axles for trusses and 4.88s!I thought so! Good talking with you and your dad.
One of my son's and I grabbed that stuff this morning just in case I run across a Comanche. I told you if you didn't grab that 8.25, I was going to! LOL!
I was looking for a trailer hitch wiring harness, the 7 pin factory one. Luckily ChipClip hooked me up. I'm good to go on that, worked out great.
As of 12:30 we’ve torn off one exhaust system, poked a hole in another and have a Jeep in a washout with a broken axle u-joint and lower ball joint.
We didn’t get too far into the trails, but we had a blast. Before the day was over the Chevy truck also busted a tie rod. That park is way harder than Harlan. It was a good day.
MARK! Good to hear from you.
