- Tacoma, wa
So I just got my rig back from the alignment shop today after I finish the install of my 3.5in lift and one ton steering and they show -2.3 degrees of camber on the driver side. After a bit of searching I’m thinking I need a 1.5 or 2 degree offset ball joint for that side right? Just want to make sure this is the “proper” fix and not just a bandaid. Also will I need another alignment after this install?
