As luck would have it, now that I'm nearing the end of the build I'm running into more electrical gremlins. I know.. I know Just Expect Electrical Problems.
My initial intent was to do a full LED exterior install along with the new High Beam headlights. This went reasonably well until I got into the signaling bulbs which were having none of it. I've swapped back and forth between the stock and digital flasher with mixed results. I added load resistors which seemed to help the back, but not the fronts.
In my frustration I've tried to just put all factory bulbs back in and save this project for another time. Unfortunately now the issue I seem to be facing is that any time I signal with either driver or passenger side the brake lights also are signaling. In my searching I've not found much information other than it might be grounds.
Any help would be appreciated.
