Dzldust
- Jacksonville,Florida
1996 XJ
Rear brakes lock up on moderate to heavy braking
Not a mud Jeep or water trails ,no brake fluid leaks or axle seal leaks
Swapped out front rotors,calipers and pads -no change
Swapped out rear drums,cylinders and shoes - no change
New soft brake lines ,bled entire system-no change
Only thing left is Master cylinder and prop valve,non-abs XJ
Good firm pedal and rear brakes are adjusted on the money
Emergency brake cable in good adjustment as well
Could this be a simple proportioning valve problem? Jeep has been a street Jeep and not abused or hacked on
