View Single Post
  #17
Old October 8th, 2020, 04:50
Vince's Avatar
Vince Vince is offline
Re: Eliminate brake self adjusters?
Just an idea. If the wheel bearing is slightly worn, the axis of the axle shaft will shift upwards relative to the axis of the brake back plate when the Jeep is on the road. This would reduce the running clearance on the lower parts of the brake shoes. It might even make the shoes have continuous contact with the drum causing them to wear and adjust repeatedly.
I'm not sure if you would notice this when rotating the wheel with the Jeep on jack stands as the axle shaft will droop relative to the backplate shifting the clearance issue to the top of the shoes. It might make a difference when the Jeep is on the road.
It's just a theory.
