View Single Post
  #16
Old August 19th, 2020, 16:31
efjellanger efjellanger is offline
Re: Throttle hanging
Started it up today after trickle charging, and it idled just fine, drove, parked, turned off and restarted, came back home. Once home I left it idling and checked voltage at the battery. With the A/C on at idle it was low (12.5 V), after I turned the A/C off it was still low (12.8 V). Even when I revved it up to maybe 3000 RPM, it showed only about 13.6 V. I think it should get up to at least 14? This would seem to suggest at highway speeds it's never able to charge properly.
