View Single Post
  #3
Old December 26th, 2003, 16:42
GI-John's Avatar
GI-John GI-John is offline
Re: replacing O rings in the oil filter neck
It's a pretty straightforward fix.... the only thing I've heard causing problems is the Torx. (some years use regular hex head, some use Torx)
Clean the bejeesus out of the elbow before replacing and lube the rings
Might as well do an oil change while you're at it.
