View Single Post
  #15
Old December 1st, 2007, 13:14
Ecomike's Avatar
Ecomike Ecomike is offline
NAXJA# 2091
Re: 96 OBD II engine misfire codes and rough idle
I found some of the fuel system details at:
http://findarticles.com/p/articles/m...n13486252/pg_3
UEL STAT 1 = Fuel System 1 Status: Fuel system status will display more than just Closed Loop (CL) or Open Loop (OL). You might find one of the following messages: OL-Drive, indicating an open-loop condition during power enrichment or deceleration enleanment; OL-Fault, indicating the PCM is commanding open-loop due to a system fault; CL-Fault, indicating the PCM may he using a different fuel control strategy due to an oxygen sensor fault.
But still looking for more details on this.
Quote=8Mud: "Go ahead and put up the best fence you can build, I'll bet on some Mexican with a few dollars of nails and a pile of scrap lumber."
34 MPG , '85 2WD Cherokee Pioneer with custom installed, 64 hp, 2.2 L Nissan SD22 Diesel 5 spd Manual; & 4 Renix XJs, '87 Wagoneer 4.0, 4WD, 89-Cherokee, 4WD, '87 Cherokee 2WD, & '89 Cherokee Pioneer 2WD, all 4dr. #2091
