View Single Post
  #12
Old December 1st, 2007, 12:43
Ecomike's Avatar
Ecomike Ecomike is offline
NAXJA# 2091
Re: 96 OBD II engine misfire codes and rough idle
Yes I found that OBD-II ford feature description quite enlighting too! I wonder if OBD-II Jeeps do that too?
Originally Posted by McQue
Thats a pretty descriptive manual you found...I have been reading through it. If you are thinking injector problems keep in mind that I read "If a single cylinder is indicated to be consistently misfiring in excess of the catalyst damage criteria, the fuel injector to that cylinder may be shut off for a period of time to prevent catalyst damage. Up to two cylinders may be disabled at the same time. This fuel shut-off feature is used on many 8-cylinder engine and some 6-cylinder engines."
Since the problem seems to be temp related, your gonna have to remember to do your testing when it's failing, but you already know that....hate to rule out something that tests good when it's all warmed up...
McQue
Quote=8Mud: "Go ahead and put up the best fence you can build, I'll bet on some Mexican with a few dollars of nails and a pile of scrap lumber."
34 MPG , '85 2WD Cherokee Pioneer with custom installed, 64 hp, 2.2 L Nissan SD22 Diesel 5 spd Manual; & 4 Renix XJs, '87 Wagoneer 4.0, 4WD, 89-Cherokee, 4WD, '87 Cherokee 2WD, & '89 Cherokee Pioneer 2WD, all 4dr. #2091
