View Single Post
Old September 4th, 2019, 07:06
azupcountry's Avatar
azupcountry azupcountry is offline
Different brake pedal feel after booster replace
2 weeks ago the brake booster failed on my 96 classic 4wd (no ABS 4.0 247k miles) while commuting home on I-4. Fortunately the stop and go traffic allowed me to feel the brake performance diminishing and hear the whistling get louder. I was able to exit and take surface roads/handbrake the last 10 miles.
FYI when the booster goes the brakes might as well be blocks of wood.
Replaced with a NAPA part without having to disconnect lines from the master cylinder.
Now, before the brakes start biting there is a bit more pedal travel. It is not soft, does not get worse and there are no leaks. I have tested on back streets by locking up brakes in forward and reverse as well as normal braking.
Is the difference in pedal travel/feel simply due to parts differences? Will bleeding the system make any difference?
Also, recently replaced rear drums/brakes but did not bleed.
Thanks!
