JMO1990renix
- SoCal
Hello to all. Thank you all in advance
I have a 1990 Jeep Cherokee xj 4.0 automatic transmission
I recently installed an sye kit. I installed the kit with the transfer case out of the vehicle. Once I installed the transfer case back into the vehicle I started it up and put it in gear and it wouldn’t move. When I went to put it in park it made a grinding noise before going into park. I got underneath with someone in the cab shifting the transfer case through each gear. Grabbing the drive shafts during the process making sure it was going into each gear.
Can anyone tell me what is going on?
Initially I though it was the shift fork in the transfer case but before I disassemble it I wanted to get some insight. It is shifting into 4wd.
