    More Information - Join/Renew
2001 Throwing P0172 & P0175
TORC811
Davison, MI
I swapped injectors and TB on my XJ while I was replacing a locked up alternator. Now that I have everything back together, the Jeep is throwing P0172 and P0175 codes. I have done some searching and will:
1) check the O2 Sensor heater fuse
2) double check all of the ground wires to be safe
3) swap the MAP sensor with a spare (AutoZone's suggestion but I don't think this is it)
4) Double check the air filter to make sure it is in good shape
More background:
2001 XJ Limited with 72,000 miles, K Suspension 12-hole injectors, and a 62mm TB that I got from ForeWheeler. The Jeep starts and idles fine in hot weather but is sluggish at low acceleration. Once I get near 2000 RPM, it takes off and runs great.
Am I on the right track? Or should I be looking at something else?
Sounds like the wrong injectors! Your about the 3rd person this month that got injectors from "K" that were not the right ones.
I have seen a couple of the other posts and am prepared for that. Just trying to eliminate other possibilities first. I would have assumed I would see a misfire or injector code if it was an injector.
What was the part# on the injectors? I think the codes your getting say it all!
P0172 1/1 Fuel System Rich A rich air/fuel mixture has been indicated by an abnormally lean correction factor.
P0175 2/1 Fuel System Rich A rich air/fuel mixture has been indicated by an abnormally lean correction factor.
I talked to him this morning. Sounds like I was part of the known bad batch. Looks like they are coming out tonight or this weekend.
Are you ones you have now #0280156161(Red)? Are they sending you the same ones?
The ones that I have now are red. I would have to verify the part number. I am not sure what he is sending me... he is waiting for another shipment.
I have a set of 4-hole (I think Bosch) coming from a buddy tomorrow to get me back up and running.
Those are to big for a stock motor. In my stroker, I'm currently running 0280155849's (4 hole version of about what you have now)and they run a touch fat when WOT. I'm thinking about trying some 0280155715's!
I've got a set of 0280156007's that are a 4 hole factory upgrade that worked great.
http://www.jeep4.0performance.4mg.com/tech_specs.html
What ever happened???
