Hi all, first time posting so feel free to berate me for any mistakes.
I bought my second Cherokee (1994/4.0/AX-15) a couple months back, and it's been pretty great. However, one big issue I've noticed so far is that the speedometer likes to stick around 35 mph, and won't move to the *actual* speed without a few hard taps to the gauge cluster. I think it's getting more stubborn as it's getting colder out, which is somewhat worrying.
The odometer and tachometer work just fine, which leads me to believe this is an issue with the speedometer itself, not a sensor or something like that.
I tried disassembling the whole gauge cluster and spraying some electronics cleaner in behind the gauge backing. Sadly, that didn't seem to help anything.
Side note, my temp and oil pressure gauges now seem to be a bit off now after the disassembly, having moved the needles around a bit to clean things up. Par for the course for my mechanical endeavors...
Anyway, like I said, it seems to be getting worse. I fear for the coming winter. Send help.
Thanks in advance!
Thanks in advance!
