gmars
5-spd 101: Make SURE everything is correct when replacing an XJ 5-spd. the clearances are so tight, that even the rebuild shop is baffled by this one!
My 97 4.0 5-spd went south, and my local tranny guy claimed to have done a "ton of them." Paid for the rebuilt AX-15, everything seemed Ok. then goign over a speed bump, and later hard braking, I heard a bizarre "rubbing" noise from under the tunnel. He insisted It was eomthing I did, and I couldn't track it down. Turned out, after puttign it on the lift, it was just diff enough form the orig that the front driveshaft was rubbing on the inside of the tunnel on full compression. Hmmm... they had used an orig "spacer plate" under the tranny that actually jacked the tranny up just a squish, enough to rub as mentioned. They called the "tech guys" who were baffled, and insisted they evne used the VIn # as a base when sendign the new one. My guess? wrong model AX-15, as a little bracket also didn't match. fascinating how goofy-assed diff these things can be, even w/in the same models and years. Hodge podge of parts availablitiy? Who knows. Be SUPER CAREFUL, even w/so-called pros. caveat emptor!
