View Single Post
  #6
Old March 15th, 2019, 08:23
SoTex SoTex is offline
Re: 8.25 rear with Disc Brakes. Problem
Buy some brake fluid if you don't have any on hand and maybe some caliper grease for the slide pins. It wouldn't hurt to bleed to calipers or lube the slide pins while you're there, but hopefully the issue is right under your nose.
