Thread: Renix Issue
View Single Post
  #8
Old October 4th, 2017, 20:40
cruiser54's Avatar
cruiser54 cruiser54 is offline
Re: Renix Issue
Originally Posted by Rob Mayercik View Post
Don't know about the Renix, but on an H.O. like mine, the ballast resistor can be bypassed and eliminated - I believe all it does is knock down the voltage to the fuel pump slightly to reduce noise. When mine fell apart, I threw it away and spliced the two wires together.
If yours is cracked, maybe the connection through it is intermittent or weak. You could try jumping around the resistor temporarily and see if it changes how it runs.
Yup. It's only there to reduce noise.
