- Northern California
Dude don’t sand too much, they are supposed to be a tight fit. Like heat the knuckle up in the oven or grill and put it on the tube at night.
If you are not narrowing, you don’t have to take them off. Just cut the weld and turn on the tube.
I had to heat them to put them back on, so I think they’re tight enough. I took them off to clean up to the old weld. Thanks for input
