Re: Greg Smith Power door locks writeup - maybe pwr windows fix, too?
Hey Greg,
Ok, since you seem to be eager for new things to conquer, I don't suppose you've got a fix (or and idea for a fix) for geriatric-slow power windows, do ya?? My driver's window works just fine, but none of the others work from the switches on the respective doors...and even from my driver's door master controls, they're "reluctant" to do what I ask of them most of the time. I've replaced the motor and regulator in the passenger front door (with one obtained from eBay, after I cleaned/lubed it and cleaned the commutator and brushes of the motor) and have also replace the seal that the leading edge of the window rides in. It's a
little better, but none perform like the driver's window. Seems similar to the original power lock problem to me. :shrug:
I've been thinking for a long time that maybe it's a weak ground, since the other up/down switches don't work (well, occasionally they do...but not very often), but I have NO idea where to start looking for potential problems. I've also changed driver's and passenger's front window/lock switch panels, but it made no difference at all.
I don't know if you'll be able to help with this problem or not...but hey, it's 'cause of you that my locks work better than they ever did, so thought it might be worth asking!!
Any suggestions or pointers would be most appreciated.
MODS - Yeah, I know this should probably be a new thread. If it ends up that there is hope for a power window fix, too, I'll certainly put it in a new thread.
Thanks again for your help, Greg! You rock!
Pyro
