XJ to tall for SWEEP
nitrospeed
vancouver wa.
Well I have been chasing rally cars as a sweep in my cherokee, 4.5 in. lift with 33x1250x15 tires for about 5 years. i am getting older now and want to lower it to a 3in. lift with 31x10.50x15 tires. I also have bushwacker 3in cutout flares wich i think i will replace with fiberglass in the front. So who makes and sells the best and cheapest set of 3in coils for driving though the woods fast? thanks
Probably the best, and stiffest, pure 3" coil is the Rancho. But, you're current 4.5" coil will be stiffer the shorter it is, so if you want it stiffer you could experiment with cutting a little off of your coil. Pretty easy to cut a coil with a cut off wheel, cut half a coil and see what you get, then cut another half a coil and so on.
x2, is what I was going to recommend... OME 2" with spacer.
Just looked at the ome coils and why the 2in with the spacer? they sell a 3in. do you think because the coil is shorter with the spacer then the handling will be better. or just get their 3in heavy duty? the 2in are medium.
A pair of OME 934 springs should get to you about where you want to be. Should net about 3-3.25" They are technically a V8 ZJ coil but will work fine on an XJ. Quite a few people run them
I think the ome 3" coils are a new. I know they use to only have the 2" springs but that was a few years ago when I was looking into them.
Dave
so you guys chase?
thank god you chose a new word for it, cause nobody knows what chasing is...
I don't know what chase is? Is it a new word for sweep?
Aren't chase vehicles team specific? Sweep teams are not.
Maybe the following links will help you in your understanding of what sweep does.
http://www.desertstormrally.com/forms/SweepJobDescription.pdf
http://members.shaw.ca/bigwhiterally/Introduction to Rally Volunteering.pdf
http://www.rallywv.com/documents/What is a rally volunteer_01.pdf
