Bleeding brakes
jeepjustice
Mount vernon
I was bleeding the brakes on my 96 and got some pedal until I started it then it went to the floor. bleed the master cylinder and all brakes, still the same problem. Is my master cylinder toast or booster bad. Ideas?
After pumping the pedal a few times did it still go to the floor?
Did you start bleeding with the right rear, then left rear then pass front then driver front?
I HATE bleeding brakes and usually when this happens it's because I did something wrong.
$26 vaccum bleeder from Harbor Freight is your best friend. ;)
