maxbraketorque
- PDX
ps you will want a good deflator kit to save a lot of hassle
https://parksoffroad.com/prodreview/deflatortest/oasis/oasis.htm
I got these, which is where I got the pressure calculator. the deflators are set to the pressure you want with a screw, and will deflate automatically to that setting, just screw it to the valve stems, when it stops hissing it is done ( I then confirm pressure with a gage) the set comes with four deflaters so all four tires can be deflated at once
These are cool. I just ordered a set.
