- Northern California
Earlier this year I had a range fork failure in my 90 XJ NP231J. I attributed to low fluid as I had a leak that I tried to fix several times but was unsuccessful. Any way a couple weeks ago my tcase chain began to slip and thought it was worn out due to low fluid as well. So I opened the case to change the chain and sprockets and found the range fork half worn out again. I can’t make sense of how the range fork is worn again already when the fluid was full. I have read that if the rod that the fork slides on is worn out that this will cause the range fork to wear but I’m not convinced either way. Any input would be very helpful, thanks.
