View Single Post
  #2
Old August 6th, 2010, 09:00
old_man's Avatar
old_man old_man is offline
Re: AW4 swap early to late
Splines are different, but if you keep the tcase that should be fine. Later model tcases use a different ouput shaft so the rear drive shaft may be problematic. The late model tcases use a different spedo connect.
You will need to swap the speed sensor in the tranny IIRC and maybe the neutral safety switch.
Tom Houston - Former Colorado Chapter President, current Treasurer , Terminal Adrenaline Junkie, and Rocket Scientist
Loveland, Colorado My teardrop build
You're just jealous because the voices don't talk to you.
