Thread: Sludge
View Single Post
  #7
Old March 7th, 2008, 07:57
garr garr is offline
Re: Sludge
The oil filter adapter is usually the biggest culprit, read this http://www.madxj.com/MADXJ/technical...Conversion.htm before you attempt the repair, Purchase the O ring kit from jeep (It cost less than $5) The repair took me 30Minutes once I rigged up a wrench to get the T-60 torx head bolt out.
I used a short 3/8 drive T-60 (From autozone) on a 3/8 breaker bar & a 3 foot lenght of heavy 1" pipe to break the Torx bolt loose.
good luck
